0 active members*
4,653 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Gecko drives- Jumping.... please HELP!!
    Oct 2011
    5
    Good morning,
    I was running my machine and it stop in the middle of the project. The machine will not respond to any of my commands. I turned off the controller, the PC, restart everything, the machine will not move.
    I opened the controller box to check voltages, capacitors, etc. , everything checked ok. Put everything back together. Upon powering the system, the machine makes short movements (jumps), and it will not respond to my commands. I disconnected the parallel cable from the controller, and again, moves erratically as described. I turned off the pc, parallel cable disconnected, turn only the controller box with the motors connected to power and to the drives and again, same movement. The lights on the drivers are Power on and Position on. This erratic movement is happening to all 3 motors. Any ideas?
    Processor: Mach 3
    Gecko 320X Servo drives
    Servo motors
    Jul 2011
    400
    Re: Gecko drives- Jumping.... please HELP!!
    Maybe try bypassing the ERR/RST if you have it connected to all 3 drives like it is usually wired. Maybe one of the drives is putting out a faulty signal to the other drives.
    Aug 2005
    1092
    It sounds like it may be a problem with an encoder.
    If the encoder has failed or not providing feedback to the drive, the servo starts to run away as the encoder is not providing feedback, so the servo trips.
    Check the encoder and the encoder wiring. It could be that the encoder cable has an internal break, due to continuous flexing in a cable track.
    Cheers,
    Peter
    Sent from my iPhone using Tapatalk Pro
    Homann Designs - http://www.homanndesigns.com/store
  1. Gecko Drives
    By Smackre in forum Gecko Drives
    Last Post: 09-12-2011, 02:12 AM
  2. Estop Gecko Drives
    By olf20 in forum Gecko Drives
    Last Post: 12-23-2008, 05:03 AM
  3. gecko drives
    By eloid in forum Gecko Drives
    Last Post: 02-20-2007, 03:42 AM
  4. About the Gecko Drives...
    By A2Nl301 in forum Gecko Drives
    Last Post: 02-09-2006, 06:26 AM
  5. Gecko Drives
    By ninewgt in forum Gecko Drives
    Last Post: 06-24-2003, 02:12 AM
