Re: Gecko G540 output 1 and 2 are always on now
Hi Justin,
It sounds like the two FETs that drive the outputs have failed “On”.
It is quite common for FETs when they fail to do so in the “On” state. It is one of the reasons why you should have an Estop that removes the power from the controller, rather than just feeding into the software to action.
My guess is that when the power supply failed it put a surge through the G540 damaging the output FETs.
Do the G540 inputs still work correctly?
You may need to replace the G540 motherboard. You can get them from Geckodrive or a distributor.
https://www.homanndesigns.com/index....roducts_id=281
The FETs could also be replaced, check with Geckodrive.
Sorry, the news is not better.
Cheers
Peter
Sent from my iPhone using Tapatalk Pro
Homann Designs - http://www.homanndesigns.com/store
