Re: Gecko G540 Touch Plate Input
As long as you are homing the axes one at a time you can double up on the limit switches. For instance, you can wire the X,Z,A and one of the Y limit switches in series feeding into a single G540 input. Then have the 2nd Y limit switch feed into a separate G540 input.
That way you have an input for the touch plate and a spare for something else, such as a spindle speed sensor.
Cheers
Peter.
Sent from my iPhone using Tapatalk Pro
Homann Designs - http://www.homanndesigns.com/store
