567,673 active members*
2,922 visitors online*
Results 1 to 11 of 11
    Jan 2011
    26
    Gene Machines OmniGrid 100
    I got a "Gene Machines OmniGrid 100" at an auction earlier this year, its a
    microarrayer, a piece of medical equipment, its made just like a CNC machine,
    when I got it, the gantry and X axis were just piled lose into the plexiglass
    enclosure, no computer and no table, just sitting on a pallet, I was told that
    in another week or two it would have been scraped, sold for scrap metal.
    I did get the controller box with power supply and servo motor drivers,
    but was unable to get the computer or the rolling table the unit comes with.
    Here is a list of parts I got with the unit.
    The servo motors are:
    X and Y axis motors = SM232BE-N10N - Peak Torque of 334 oz-in, weighs 3lbs
    Z axis motor = CM162AE-01086
    The rails are:
    X and Y axis rails = 404600XRMS - they have a working length of 600mm / 23.622047in
    Z axis rail = 404100XRMS - has a working length of 100mm / 3.937008in
    The power supply is:
    Astec 800w power supply, 60V @ 12A, 24V @ 4A, 5V @ 10A
    The servo drivers are:
    (x 3) OEM670T Torque Servo Drives
    And lots of small pieces of T-slotted aluminum profile 1x1 inch, and various
    related T-slotted aluminum profile hardware that went into the making the
    OmniGrid's Plexiglas enclosure, the enclosure was so huge I had to dissemble it.
    I was thinking of replacing the servos and drivers, with three KL-8060 Drivers
    and three KL23H2100-35-4B stepper motors, and reusing the 60V power supply, I was
    also thinking about putting the gantry on 20mm SBR Supported Linear Rails and
    increasing the CNC size from around 24x30 inch to something like 24x48+, and I
    was going to use a 1/2-10 five start lead screw to move the gantry, any ideas?
    I posted some more info some time ago in this post made by someone else
    who also got one.
    Communicating with 3-Axis Microarrayer Via SCSI
    Here are two Youtube videos of an OmniGrid 100 being used.
    [ame="http://www.youtube.com/watch?v=Pjr1Oyc0KrY&feature=results_main&playnext=1&list=PL4D0425E60BAFC81C"]Microarrayer [/ame]
    [ame="http://www.youtube.com/watch?v=Duw0oE2Qi0I&feature=plcp&context=C3c6085cUDOEgsToPDskJFhA7x37_-MeriJqaF3Ah0"]Microarray printing [/ame]
    And a large image of one setup for use.
    GeneMachines Omni Grid 100 arrayer
    Nov 2006
    1036
    Congrats!!! Those are three very fine Parker Daedal linear slides!!! On at least some of these slides, the other numbers after the 404600XRMS and 404100XRMS give details about the ball screw, motor mount, and sensors built into the slide. If the numbers are there and you care, I think I have a link somewhere to that data. BTW the "100" and "600" refer to mm of travel.
    Jan 2011
    26
    Quote Originally Posted by DonFrambach View Post
    Thanks, as far as I can tell there are no sensors built into the rails, but there were what looked
    like hall effect sensors attached to the rails, I am going to replace them with lever micro switches,
    I am right now planning out my spending over the next few months, limited funds, so I am trying to
    get a game plan on what I am going to build.
    I have thought about setting the OmniGrid up the way it was, in that configuration
    it would mill aluminum easily I think, but milling aluminum would not be something
    I would do very often.
    I thought about making the bottom part of a Joe's CNC Model 2006 and attaching
    the OmniGrid gantry to it, but my current CNC router only has a 12x17 inch working
    area.
    The other idea is using 20mm SBR Supported Linear Rails on each side of the OmniGrid
    gantry, this idea seams easy but I wonder about using 2 motors on the X axis or would
    one be good enough.
    Jan 2011
    26
    I got looking around at different designs that use linear rails, SBR and other, and
    found a few designs close to what I was thinking about here in the forums.
    My Pilot Pro Ex Extended
    my 4' x 4' table build
    rebuilding my 1 year old router)
    Proposed router design. comments please
    The Green Machine
    And I bought the Pilot Pro Plans DVD today, and I have bought a bunch of plans over
    the years, but none of them seem easily adapted to what I want to do except maybe the
    Solsylva plans, I got them last year, I will have to look over both of them to get some ideas.
    Jan 2011
    26
    Quote Originally Posted by william1384 View Post
    I got the Pilot Pro Plans DVD in the mail yesterday, the plans are in cad files and
    supporting text is in Microsoft Word format, if you dont know cad that well, the Pilot Pro
    plans can be a little hard to figure out.
    I also had trouble with the Pilot Pro Plans DVD not wanting to mount on my PC running
    Linux, but the DVD worked fine on my Windows PC.
    I am going to spend the next week or two looking over both Pilot Pro and Solsylva plans,
    but I am starting to think I should just do what I first thought about and just use two
    20mm SBR Supported Linear Rails, one for each side of the OmniGrid gantry, I am
    still not sure about using one or two motors on the X axis.
    I will make the table first, I am going to make the table top from MDF and 2x4s and
    use screws to put it togather, and will use 3/4th pipe and pipe fittings for the legs.
    My plan is to make the table, something like 40in x 60in, and just bolt the Linear Rails
    to the table top, or mount the Linear Rails to square tubular steel, then mount the square
    tubular steel to the MDF table top.
    Jan 2011
    26
    I have decided to have the OmniGrid set up the way it was originally, and
    plan to buy the "G540 3-Axis NEMA23 381oz in PSU48V/7.3A" kit from
    kelinginc.net, I will have to make a nema 23 motor plate for the Z-axis
    as the Z-axis that I have uses what looks like a nema 17 motor plate
    but with non-standard bolt hole spacing, the good news is I actually
    found cad drawings from the company that made the Z-axis, and they
    have drawings for a nema 23 motor plate that fits the Z-axis, but I will
    have to cut it out of lexan as my small CNC router that I have now is
    unable to cut aluminium.
    I have all the parts to make a table to mount the OmniGrid on, but I have a
    problem with mounting the X-Axis to the table, they used toe clamps that
    were made just for the linear slides, and are very hard to find, and very
    costly, if I had a milling machine I could make them, as they made cad drawings
    available, and there are holes on the underside of the linear slides, but they are
    un-threaded, and the metal looks to be about 1/8 thick or less, also the holes
    go directly into were the lead screw is, so I think that they would be unsuitable
    for using as bolt holes, it looks like I will have to make my own toe clamps.
    May 2003
    162
    William,
    Excellent score, those actuators are around $2000K each, or more.
    Here is what I did with my Parkers, I hope it is a bit of inspiration for you...
    Frame is 4x4 alum, and t-slot top. Hitachi M12VC 2.25HP router.
    Accuracy and surface finish is excellent.
    I am running Nema dual stack Nema 23's with Parker Microstepping drives that put out 160V to the steppers, I have them set at 1.8A. The drives take 120V directly in to each drive.
    Extra pic inside one actuator to view the yumminess....mmmm...ground ball screws.
    I can't believe they were going to "scrap" those for metal.
    May 2003
    162
    Oh and William...
    I used those "bolt holes" inside.
    What you want is "Metric Low Head Socket Cap Screw Class 8.8 Steel, M6 Size, 20 mm Length, 1 mm Pitch" I got mine from Mcmaster-Carr. Here is the part #: 93070A147
    Feb 2012
    omni grid - control?
    I also have acquired an old Gene Machine Omni Grid. I have the controller as well...however, no software.
    How have you guys been able to control your systems?
    Jan 2011
    26
    Quote Originally Posted by foam27 View Post
    Oh and William...
    Thanks!
    Quote Originally Posted by wzc0014 View Post
    I was not able to get the PC that comes with the system, so no software,
    and to me, it looked like to much trouble to use the servo and there drives,
    so I decided to just replace them, I plan to sell each servo with its own
    driver and wires on ebay.
    On of the other people here was able to move the servos with the
    Gene Machine Omni Grid software, but they never posted what they
    ended up doing to the system.
    Oct 2008
    Re: Gene Machines OmniGrid 100
    I know this is an old thread, but I just picked up the same GeneMachine Omni Grid system in an auction as I was excited about some of the other bits bundled with it. Was trying to figure out what to do with the linear rails, motors and other bits. This is an interesting idea and was wondering how it ended up? Does your CNC work well? I am just getting into CNCs, bought a Makera Carvera Desktop system and having fun, but I could see this new hobby expanding and needing a larger machine and if I just stumbled into most of the needed parts this could be very cool. Can anyone share their experiences?
  1. REPLACE SYIL MACHINES WITH AMERICAN MADE MACHINES
    By heilcnc in forum Benchtop Machines
    Last Post: 08-24-2009, 07:53 AM
  2. gene
    By genem in forum Uncategorised MetalWorking Machines
    Last Post: 01-21-2009, 10:03 PM
  3. gene
    By gene1157 in forum Fanuc
    Last Post: 06-20-2008, 08:42 AM
  4. Gene Haas
    By ddprecision in forum Haas Mills
    Last Post: 11-07-2007, 09:04 PM
