508,526 active members
2,922 visitors online
IndustryArena Forum > 3D Milling Machines > General Full 3D Wood Router Machines
IndustryArena Forum: General Full 3D Wood Router Machines
Page 2 of 5 1234
Threads 21 to 40 of 86
Discuss General Full 3D Wood Router Machines
  1. new labtop will not run mach3 on my diy router
    Started by bmillmine, 04-30-2015 11:26 PM
    cnc, controller, movement, router, thing
    05-01-2015, 12:30 AM Go to last post
  2. Deep Z CNC Machines... Who's Got them?
    Started by BlueRealm, 10-02-2011 04:36 PM
    2 Pages
    1 2
    04-28-2015, 10:11 PM Go to last post
  3. Need help Circle more like OVal
    Started by shanoger, 04-09-2015 09:58 AM
    04-21-2015, 07:40 PM Go to last post
  4. Surfacing Anomoly
    Started by RHT, 03-30-2015 04:35 PM
    04-09-2015, 03:43 PM Go to last post
  5. Need help routing/ reaching deep pockets.
    Started by FoxCNC1, 03-23-2015 04:36 AM
    bit, correct, longer, router, tools
    03-23-2015, 11:37 AM Go to last post
    03-23-2015, 04:51 AM Go to last post
  6. What kind of spindle is this?
    Started by cletero, 03-12-2015 03:17 PM
    03-12-2015, 10:10 PM Go to last post
  7. my second manufacturing cnc
    Started by GANADERO, 11-28-2014 10:14 PM
    4x8, cnc, cut, cutting, cutting wood, design, feedback, guys, hours, machine, manufacturing, opinion, plasma, plasma cut, plasma cutting, router, seco, table, time, wood, work
    11-28-2014, 10:14 PM Go to last post
  8. 4th Axis Information Please
    Started by th3t1ck, 11-15-2014 04:11 AM
    3 axis, 4 axis, 4th, 4th axis, 5 axis, add, axis, cnc, cnc work, controller, ebay, familiar, formation, information, lathes, metal, purchasing, roller, setup, wood, work
    11-15-2014, 10:03 AM Go to last post
  9. Industrial 2X3 CNC Router
    Started by saudomran, 09-16-2014 04:15 PM
    2x3, buy, cnc, cnc router, cut, er system, good, industrial, ion, looking, need, new, new to cnc, rail, route, router, shortcut, suggestion, sys, system
    09-16-2014, 04:15 PM Go to last post
  10. CNC ROUTER 3 AXIS - BUILDING
    Started by cncspadeto, 08-24-2014 05:39 AM
    3 axis, art, axis, beginner, buy, cnc, cnc router, computer, ebay, electronic, electronics, first cnc, free, kit, mach, mach3, motor, parallel, problem, router, stepper, teaching, wood
    08-24-2014, 05:39 AM Go to last post
  11. CNC 5 AXIS
    Started by cncspadeto, 08-24-2014 01:53 AM
    5 axis, axis, cnc, code, construction, control, driver, ebay, font, g-code, generator, home, kit, mach3, machine, motor, nema, newbie, router, stepper, wood
    08-24-2014, 01:53 AM Go to last post
    05-21-2014, 01:57 PM Go to last post
  12. AXYZ 4008 ATC Scenic Carpentry
    Started by WayneNero, 02-24-2014 03:35 AM
    03-28-2014, 05:33 PM Go to last post
  13. Some questions about chinese 2.2 kW spindle.
    Started by kayakman, 03-19-2014 05:54 PM
    220, amps, chinese, input, kit, marking, motor, questions, seller, set, settings, speed, spindle, vfd, volts
    03-19-2014, 05:54 PM Go to last post
  14. How slow can a router go?
    Started by Flap1, 02-24-2014 01:08 AM
    bosch, cnc, cut, deep, end mill, feed, feedback, flexible, flute, home, machine, machinist, made, mill, plastic, router, rpm, simple, slow, speed, spindle, tolerances, variable, variable speed, work
    02-24-2014, 03:19 PM Go to last post
  15. Bougth a Crap China CNC Router!
    Started by winemuppet, 08-23-2012 10:27 PM
    2 Pages
    1 2
    suppliers
    01-16-2014, 10:20 PM Go to last post
    01-08-2014, 01:13 PM Go to last post
  16. Pro 4848 z axis issues
    Started by peterkallas, 11-16-2013 01:54 AM
    12-06-2013, 12:29 PM Go to last post
  17. Red face Standalone Driver Boards for a Novice
    Started by simplemachinist, 11-03-2013 04:24 AM
    11-03-2013, 04:24 AM Go to last post
Page 2 of 5 1234
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
