585,967 active members*
4,288 visitors online*
IndustryArena Forum > CAD Software > Rhino 3D > Give angle of exit or demoulding
    Feb 2012
    87
    Hello all, I want to give angle of departure of 14 degrees to the letters, I want to know how you can do? thanks you
    Dec 2003
    1224
    Re: Give angle of exit or demoulding
    Are you intending to produce individual letters or cut letters into an object?The process is fairly similar in that you select the outline of the letters and use the extrude curve-draft feature to create the surfaces or solids you require and you will be prompted for the draft angle,which in your case will be 14 degrees.The depth will be positive or negative according to your needs as mentioned earlier.
  1. Entry and Exit Marks
    By CYoung in forum Avid CNC
    Last Post: 11-29-2015, 01:28 AM
  2. Angle Iron Vs. Angle Aluminum for V Bearings
    By estes53 in forum Linear and Rotary Motion
    Last Post: 07-29-2015, 11:15 AM
  3. No Exit Moves After Finish!
    By Machineit in forum BobCad-Cam
    Last Post: 09-25-2012, 11:40 PM
  4. Exit Wounds and De-burring
    By aucran in forum MetalWork Discussion
    Last Post: 08-06-2010, 04:06 PM
  5. G70 exit commands with a -u.
    By rapidtraverse in forum Haas Lathes
    Last Post: 01-14-2008, 04:34 AM
