Hello all
I want to eventually upgrade my home machinepark, that means cnc router, cnc lathe, and cnc mill. This thread is a search for a design to replace my current cnc router.
What i have today is a machine made out of steel square tube, workspace about 3000mm x 1500mm i think its about 10ft by 4ft. The reason i want to upgrade it is because its not rigid enough, in short i cheaped out on the steel. If i remember correctly its made out of 50mm x 50mm x 3mm? (2"x2") looking to build using around 100x100x5-10mm(4"x4"), it also uses round supported linear rails wich aint that good.
I have earlier come across builds that i like and looks to work great, however now that im looking to revisit them i cant seem to find themso it would be helpfull to me if you would want to drop links to builds that you like that are on the heftier side(doesnt need to be made of steel but it probably where im going).
Been glancing at lowpriced commercial machines for clues but they weigh tons and thats to much.
