540,709 active members*
6,540 visitors online*
IndustryArena Forum > MetalWorking Machines > OKK > Got a problem with OKK MCV 520.
    Jun 2014
    Hello Everyone!
    We did a transport on our OKK MCV 520. The System on it is a Fanuc, its an old machine.
    When we plugged in the machine we got an error code: "EX 37, Broken Thermal For Motor"
    Anyone got any idea where to start?
    Oct 2007
    106
    Re: Got a problem with OKK MCV 520.
    This was one year ago so I assume that you already found the solution.
    I had the same alarm, it was an open line of 24VDC thas goes thru the magnetic/thermal breakers.
    I
    Mar 2021
    Hello, I just plugged in ab old OKK MCV820 that I picked and I'm getting the same error code: Broken Thermal For Motor, can anyone elaborate on erd39030's response?
  1. Having problem with CNC driver/card problem
    By todatop in forum Commercial CNC Wood Routers
    Last Post: 04-09-2014, 05:45 PM
  2. Tube problem or powersupply problem? Help you to check out
    By Melody-gweike in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 10-05-2012, 04:09 AM
  3. daewoo puma 12lb tape format problem/parameter problem
    By robb12877 in forum Daewoo/Doosan
    Last Post: 08-25-2011, 06:13 AM
  4. Replies: 5
    Last Post: 08-04-2010, 11:33 PM
  5. machine problem or software problem?
    By bcnc in forum Syil Products
    Last Post: 10-26-2009, 03:51 PM
