Hi;
I have received my C10 breakout board from CNC4PC. I want to know a bit more about the connections before I hit the power switch. The pull-up or pull-down option has me a bit confused.
I want to run 3 steppers (4 eventually) with Mach3 software from the parallel port. I will use db25 cable pins 1-17 as outputs (pins 2-9 as step and direction).
Can anyone clear up the pull-up/down resistor thing? How do I determine which I need? I know I set this with a jumper, but pull-up or pull-down?
Also, with Mach3 software, is the chargepump connected to the C10 enable pin? Or should I just connect a jumper from +5V to the enable pin to get the whole system running?
I'm just bench testing for now. I don't own a mill yet. To early to hurt myself!
I just don't want that puff of smoke when I switch on.
Thanks, Tom.
