600,887 active members*
2,917 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > GRBL servo Z axis + unipolar driver library
    Apr 2018
    is there an Arduino GRBL library mod that supports both Z axis with servo and unipolar motor drivers (4 wire uln2003)?
    I found a mod library for unipolar motors and another one using standard bipolar motors and servo control for Z axis.
    I could eventually blend them but It would take unknown amount of time to find the corresponding mods.
    I am building a pcb engraving plotter with 28byj-48 motors and a servo on Z.
    I know there is a mod for the motors to turn them bipolar but I think the torque is ok (2 motors per axis) and have to rewire the build for new motor drivers.
    Mar 2015
    441
    Re: GRBL servo Z axis + unipolar driver library
    The arduino (UNO, Mega) grbl software outputs a step/dir/enable signal. As long as the driver can handle these signals, you are OK. And that is where you get into trouble. Your UNL2003 requires a lot more than just step/dir/enable signals.
    Modifying grbl to accept unipolair drivers is a huge project and due to lack of memory, not feasible for an Arduino UNO. I think getting a grbl compatible board/shield and some step stick drivers (TMC2209. DRV8825) would be more feasible.
    Apr 2018
    It works with uln2003 drivers + Z servo:
    -https://youtu.be/f6xCfzfiD6Q
    This is the library:
    -https://github.com/ruizivo/GRBL-28byj-48-Servo
    It is a bit tricky if you want to change the stepper motor and servo pwm pins to different ones than these in the library.
    And it works with Arduino nano.
    I am currently having some strange issue that the video maker does not have (he runs some plotter with Z servo and uln2003 driven motors).
  1. Replies: 5
    Last Post: 04-07-2021, 08:34 AM
  2. sla7033 stepper motor driver (unipolar driver?)
    By Emanuelg in forum Stepper Motors / Drives
    Last Post: 01-12-2017, 10:54 PM
  3. GRBL with unipolar Steppers Information required
    By mb.raghavendra in forum Open Source Controller Boards
    Last Post: 12-03-2015, 09:07 PM
  4. UNIPOLAR DRIVER WITH L297
    By wl888 in forum Open Source Controller Boards
    Last Post: 10-25-2012, 12:24 PM
  5. 3 axis unipolar motor driver board
    By serkanozfe in forum Stepper Motors / Drives
    Last Post: 02-15-2005, 08:28 AM
