504,510 active members
3,286 visitors online
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > GrblGru: Free CAM and 3D-Simulation for mills and lathes
Page 1 of 19 12311
Results 1 to 12 of 225
    May 2016
    123
    I'm only recently in this forum and this is my first post. But in this time I've seen already a lot of lathe users looking for a free CAM program.
    So I would like to inform you about my free program GrblGru. It provides CAM functionality and 3D simulation for milling machines and lathes. In command mode (G-code sender) it can communicate with GRBL as well as TinyG.
    I use the program for my little DIY milling machine and my old lathe, that I've updated to CNC. Now I'm looking for good ideas to improve it.
    If you like to give GrblGru a try, you can download it from my dropbox at https://goo.gl/quFpdZ
    It's running under windows operating systems since XP.
    On my youtube channel you can follow the history of GrblGru from the beginning in 2014 until now.
    For lathe users maybe
    https://youtu.be/GXnGWg4jOtY
    gives you a good imagination about how GrblGru is working. Also my latest video, attached below, shows a large wood lathe in simulation mode.
    For milling machine owner maybe my DIY 4th axis is interesting
    https://youtu.be/HBvy4BS_Q7s
    https://youtu.be/_H3ZKvBRc8Q
    Any suggestions for improvements and also critique are welcome
    Have fun with GrblGru :)
    @Admin
    I'm not sure if this is the right category for my post. Please move if not. Thanks
    May 2016
    123
    Re: GrblGru: Free CAM and 3D-Simulation for mills and lathes
    As is well known GRBL and TinyG supports no macro programming such as e.g. LinuxCNC.
    But in my new program version V3.2 I've added a library (https://github.com/NRSoft/GSharp), which allows the using of G-code with variables, conditions, loops and subroutines.
    See in the attached video how to use GrblGru as development environment to create and debug G-code.
    Please note, that the real possibilities of the g# maro language are much more powerful.
    For details see e.g. http://linuxcnc.org/docs/html/gcode/overview.html
    Free download GrblGru V3.2 from my dropbox: https://goo.gl/quFpdZ
    https://www.youtube.com/watch?v=5UIV...ature=youtu.be
    Jul 2016
    There is a way to support Repetier/Marlin firmware on RAMPS shield? I'm looking for this toolchain [cnc 4 axis - xyza axis->repetier->ramps1.4->mega2560] a way to verify and send gocde
    Inviato dal mio MX5 utilizzando Tapatalk
    May 2016
    123
    Sorry, I've only experience with GRBL/Arduino Uno and TinyG. I've never try to send GCode to Repetier/Marlin at mega2560.
    But you can use GrblGru to verify your GCode. It's also possible to add a 3D-model from your machine or axes construction.
    May 2016
    123
    I only would like to inform you about my new GrblGru Version 3.3
    Now it's possible to add also your own lathe fixtures like face drivers and mandrels.
    Just add the STL file from your fixture into the GrblGru fixtures folder and it will be shown in the 3D simulation.
    So, before you go to your dark, cold workshop you can check the complete clamping situation and the turning process in your warm, nice armchair.
    Please inform me in case you get problems or have questions about adding 3D models of your fixture or machine. I'll give you any assistance.
    Free download GrblGru v3.3 from my dropbox -> https://goo.gl/quFpdZ
    https://www.youtube.com/watch?v=vQF7...ature=youtu.be
    May 2016
    123
    I would like to inform you about a new GrblGru version V3.4. Free Download: https://goo.gl/quFpdZ
    Proud to present the 3D model from, in this forum well known, user 'Yohudi'. He has created the 3D model with 'gmax' and has added it to GrblGru.
    Danny, thanks again for your support !
    Attachment 334996
    May 2016
    123
    Again I would like to inform you about a new GrblGru version V3.5.
    I've improved the slicer function. With the new 'Multi Cut' mode now it's also possible to slice STL objects into many layers.
    If you are still looking for some Halloween stuff, maybe it's interesting for you to see in the attached video, how you can build a 'pumpkin mask' for your kids with the slicer.
    GrblGru free download from my dropbox: https://goo.gl/quFpdZ
    May 2016
    123
    In my new GrblGru version I've reworked the DXF templates, especially the gear template.
    So the main topic of version V3.6. is the involute profile and the way to build a planetary gear set.
    Planetary gears are very interesting. Because it's not possible to show all details in a short video,
    I recommend to build the gear set by your self. I've attached a normal dxf file with all parts. Please note that all is in metric units.
    So, you can use your favorite CAM program to carve the gears. I promise that you'll be excited when you turn the sun gear and see how it works.
    If you like to know how to design a gear with a beer can (without any help from a program), have a look to the attached video.
    Free Download V3.6 from my dropbox: https://goo.gl/quFpdZ
    https://www.youtube.com/watch?v=l9u2...ature=youtu.be
    Gold Member
    Apr 2006
    3501
    GrblGru,
    I never seen such a dedicated hardworking programmer making such a nice application all alone... My salute to you and your such a nice work. Thanks for sharing with us man...
    I wish you be my friend.. love your dedication and hardwork.
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
    May 2016
    123
    Thanks for your kind words. But for me this is no hard work. I have fun to continue developing and improving my little program.
    Also I'm happy if somebody can use it.
    Dec 2016
    Hi GrblGru! Your software is amazing! Great job and thanks for share! I'm trying to create g-codes and use them in my lathe CNC. I'm such a beginner and I'm probably making some simple mistakes. I tried to follow the manual and the video tutorials, but the version I downloaded is 3.6 and I can't not translate the commands of the manual (older version) to my version. Is it possible to download the older versions? My main problem is that I can import DXF files, but I could not generate the G-code properly. The g-code I get are only the headers. As I said, I'm probably making some simple mistakes, I don't find where I should define the Start Diameter value, for example. (When I click "NC" button, this value is not asked).
    (English isn't my first language, please excuse any mistakes )
    May 2016
    123
    Hi _Aline_,
    sorry, I know that my documentation is not up to date. But the program is still in development and all things are changing.
    I've created a little movie and uploaded it to my dropbox. https://goo.gl/jS0Ndxhttps://goo.gl/jS0Ndx
    It shows the using of the lathe mode. Hope this helps a little bit.
    Please inform me if somethings goes wrong. Sure we will find a solution.
    Thanks for giving GrblGru a try.
Page 1 of 19 12311
  1. Affordable CNC Mills and Lathes
    By cweber in forum Uncategorised MetalWorking Machines
    Last Post: 04-20-2013, 10:44 AM
  2. D&M Lathes, Mills, etc.
    By boatlover in forum Benchtop Machines
    Last Post: 04-25-2008, 02:39 AM
  3. Birmingham Mills and Lathes
    By smilenbseen in forum Uncategorised MetalWorking Machines
    Last Post: 01-23-2007, 01:19 AM
  4. Birmingham Mills and Lathes
    By smilenbseen in forum Vertical Mill, Lathe Project Log
    Last Post: 01-02-2007, 01:42 AM
  5. Darn near FREE LATHES!!!! - 2 lathes, gotta go NOW!
    By mxtras in forum Uncategorised MetalWorking Machines
    Last Post: 03-22-2006, 07:43 PM
