554,027 active members*
2,458 visitors online*
Thread: H100 vfd
    Jul 2022
    H100 vfd
    I set p080=4 now the vfd runs on startup and I can't stop or reset
    And YES IKNOW I F ed up. Anyone now how to shut down/stop
    Jan 2005
    14292
    Re: H100 vfd
    Quote Originally Posted by JDMTA View Post
    What is the Manufacturers name of the VFD Drive H100 does not mean much
    Or if you have a link to the PDF manual would also work
    Mactec54
    Jan 2005
    14292
    Re: H100 vfd
    Ok, I have the Manual so check to see if F000. =0 if (1) the Parameters are locked you can disconnect the spindle while trying to get it working again
    Just set P080=0 back to (0) for normal operation, if you can't Reset this Parameter, you will have to do a Factory Reset, and reprogram the Drive to suit your spindle specs
    Mactec54
  1. H100-2.2C2-1B VFD to C11G Board
    By bigrock in forum Spindles / VFD
    Last Post: 01-08-2022, 11:53 AM
  2. Huajiang VFD H100 and 1.5KW Spindle Speed Control
    By clockstick in forum Spindles / VFD
    Last Post: 01-25-2021, 01:43 AM
  3. Replies: 1
    Last Post: 10-09-2019, 01:25 AM
  4. Replies: 1
    Last Post: 01-04-2014, 01:43 AM
  5. doosan ACE-H100 pallet APC arm return fault
    By suresh patil in forum Daewoo/Doosan
    Last Post: 10-01-2007, 04:30 AM
