600,787 active members*
4,564 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > Haas 300 Servo Bar feed problems
    Dec 2020
    3
    I have just bought from auction a Haas ST10Y with 300 Servo bar feeder. Year2012. They were bought as a running sety-up.
    I have wired it in and plugged the air up..
    When I start the machine up and power up to home the axis's, the V-axis (bar feed) slowly feeds the bar feed. It will keep pushing until it overloads at the end of its travel.
    My question for people with a similir machine combintaion. When you first start the machine up and home all axis's, does it start with the V-axis? I'm just wondering if mine, is my machine is not receiving a signal back from the bar feed to say it has moved.. So it continues to push
    I can not get past this point to home any of the other axis's on the machine,
    Any help would be appreciated.
    Re: Haas 300 Servo Bar feed problems
    Quote Originally Posted by stew205 View Post
    The V-axis is not seeing its home switch (proximity or mechanical limit switch).
    Or the signal is not getting back to the control, so it keeps “searching” for home, thinking it’s not there yet.
  1. HAAS Servo Bar 300 Push Speed
    By Turning4Life in forum Haas Lathes
    Last Post: 12-19-2021, 05:08 PM
  2. Haas Servo Bar 300? Pushing part out to a stop.
    By bushing in forum Community Club House
    Last Post: 07-17-2013, 08:24 PM
  3. Replies: 2
    Last Post: 04-03-2012, 04:31 PM
  4. New lathe: Servo 300 versus other / used bar feed?
    By peter.blais in forum Haas Lathes
    Last Post: 10-12-2010, 09:38 PM
  5. RFQ haas SL-20 to Haas bar 300 alignment plate needed
    By J-Mccoin 2009 in forum Employment Opportunity
    Last Post: 10-28-2009, 08:17 PM
