585,991 active members*
6,624 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas HRT210 P3 help parameters
Results 1 to 1 of 1
    Sep 2006
    First ever post.
    I have a 2011 VF2SS with software 18.05A.
    Just bought a used HRT210 P3.
    Under setting 30 I do not have HRT210 P3 option to choose.
    Called my local HFO and they sent me the parameter list for a HRT210HS P3 and after changing the parameters I get alarm 106. I called them and they said they don't have a list for the HRT210 P3 and I asked them if the can cross reference them to a machine at their location but they don't have one. So what I would like is if someone could send me the parameters for the HRT210 P3 or look at what my HFO sent me and see what parameter is different on their machine under the HRT210 P3.
    I opened the side of the 4th axis and the pulley turns freely so the alarm is not caused by it being bond up.
    Attached Files Attached Files
  1. Haas HRT210 motor replacement
    By astro in forum Haas Mills
    Last Post: 10-26-2019, 07:59 PM
  2. Haas HRT210
    By rrbmachining in forum Haas Mills
    Last Post: 06-06-2010, 06:16 PM
  3. HAAS HRT210 wiring diagram
    By jcassidy in forum Haas Visual Quick Code
    Last Post: 03-11-2010, 09:34 AM
  4. Installing / Removing HAAS HRT210 4th AXIS
    By glenn105 in forum Haas Mills
    Last Post: 01-21-2010, 07:49 PM
  5. Haas VF with HRT210 indexer, M21
    By Talisman in forum Haas Mills
    Last Post: 10-23-2009, 04:02 AM
