Re: Haas Office Mill (OM-2A)
Originally Posted by
Time123
Hello,
My problem is that when trying home the Z axis the unit does not see the proximity switch (I believe) and the unit runs completely to the top and jams up. I replace the proximity switch, the switch is normally close- light is on and does change state when I place a screw driver on it. X & Y axis work find. When I look down the back side of the unit, I do not see a trip flag and not sure were it would be located?
If replace a new proximity switch still the same problem, you might need to check the feedback from the proximity switch to the CNC controller.
