530,179 active members*
3,307 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas rotary/indexer controller protection
Results 1 to 5 of 5
    Jun 2007
    43
    We have Haas rotary/indexer controller box and some of the parameters are protected. Is there any way to unlock the protections. I know that you have to call Hass to get ther code. Is there any way without call ing them? Any formula?
    Apr 2007
    178
    parameter 30 times 1027 then convert to hexadecimal then invert the last 2 pairs to the right of numbers ie: if you end up with 1b52then make it 521b then take this number and convert to decimal then type the result into parameter 30 immediately goto parameter 24 and subtract 8 to keep the lock off.
    REYTECH Machine Service Corp. CNC repair NY, NJ
    http://www.reytechmachine.com
    Dec 2009
    Re: Haas rotary/indexer controller protection
    This works -- Thank You !!!!!! - i have a haas s5c rotary indexer
    Mar 2008
    632
    Lol. Ah, fun times
    Dec 2013
    I couldn't get this to work. I have an old box from 2004. It has 5 digits in the parameters and I keep getting an 8 digit code with this formula.
  1. haas rotary indexer
    By beno68 in forum Community Club House
    Last Post: 12-06-2013, 08:20 PM
  2. Replies: 1
    Last Post: 10-05-2011, 02:39 PM
  3. Rotary Indexer Help
    By GM81 in forum Fadal
    Last Post: 05-03-2011, 04:12 PM
  4. Overload protection on a Rotary Phase Converter?
    By CATCH22 in forum Phase Converters
    Last Post: 07-25-2009, 03:13 PM
