584,833 active members*
5,702 visitors online*
    Feb 2015
    13
    HAAS VF-2I Axis lubrication
    Hello Everyone,
    I have a Haas VF-2I machine. It had a error code 2082. Our Haas service agent has changed the Axis lubrication cycle time to 8 hours. (I don't knw exact default value, but 8 hours is too much) As I know, Error 2082 occurs before starting axis lubrication if there is clot of grease in lubrication lines.
    So, there is no any solution of increasing lubrication cycle time. Its negatively affect for machine function drastically. Also service agent has performed some cleaning and they have used pressurized compress air line to remove the clot in the line. What they done is unplugged the lubrication inlet lines and used a compressed air line. But according to Haas website have to use special liquid and a pressure gun for this. I don't know either it will removed the clot or get more stuck. When I manually activated the lubrication solenoid It shows only 2.5bar as lubrication pressure now.
    Hope you can understand above description and please tell me your ideas about this service done by Haas agent and tell me what is the default lubrication cycle time and lubrication pressure for Haas VF-2I.
    Thank in advance.
    Lubrication cycle time setting
    Maximum lubrication pressure
    Jul 2022
    Re: HAAS VF-2I Axis lubrication
    HELLO
    DATE OF MANUFACTURE OF THE MACHINE
    IS THE GREASE TUPE
  1. Haas mini mill lubrication pump problem.
    By Mike T. in forum Haas Mills
    Last Post: 11-20-2019, 05:52 PM
  2. Axis lubrication issues
    By 2015imsjfw in forum Okuma
    Last Post: 07-12-2018, 07:41 AM
  3. axis lubrication parameters
    By deadlykitten in forum Okuma
    Last Post: 08-25-2016, 09:05 AM
  4. Haas VF Linear Guides Lubrication
    By Alex VF in forum Haas Mills
    Last Post: 11-30-2009, 08:08 AM
  5. Axis Lubrication - Multus
    By zooloader in forum Okuma
    Last Post: 08-18-2009, 04:02 AM
