585,959 active members*
4,701 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas VF2SS reoccurring alarm.
    Hello
    I’m currently running VF2SS. At least 50% of the time whe tool changes. I get an alarm “unexpected surface”
    Any clues
    Jan 2005
    15362
    Re: Haas VF2SS reoccurring alarm.
    Quote Originally Posted by cosmo2000 View Post
    Hello
    Any clues
    Do you have a probe if so here are what can be the fixes
    Interference from the work lights. ( Adjust the work lights )
    Settings in the work probe are not correct. ( Correct the settings. )
    The surface of the part was found, when not expected. ( Edit the program. )
    Occurs if the probe is already triggered before a move or triggered while positioning the ( Clear faults and restart from safe position, check if chips are trapped around probe eyelids )
    probe or tool.
    Mactec54
