600,789 active members*
4,360 visitors online*
    Mar 2025
    Handheld Controller Upgrade??
    Hello all,
    I have a Phantom S series with an RichAuto A11E handheld that has gone out on me. I am wondering if I can replace that with the RichAuto B51E as either a direct replacement, meaning just connect it to the existing umbilical, or if I have to replace the board in the cabinet. Has anyone made this change to their CNC? If so, what was all involved and what has your experience been?
    Re: Handheld Controller Upgrade??
    1 If you change to B51 E, you need to consider whether the size of the new control board in the control cabinet is sufficient
    2 You need to reset the working area, pulse, tool block depth, etc.
    3 Is the reason for changing to B51E mainly to see the path on the handle?
    In addition, it is recommended to contact me to find out the performance of the old handle breaking, in case it breaks again after you change to a new handle.
    My whatsapp +8618560201508 [email protected]
  1. 0501 Controller upgrade to Rich auto A11 or F741B controller
    By ecoworld in forum Commercial CNC Wood Routers
    Last Post: 05-19-2024, 07:03 PM
  2. Controller Upgrade?
    By Mike M in forum Servo Motors / Drives
    Last Post: 11-06-2019, 02:37 AM
  3. Need Help with 2014 SCM Pratix S15 Handheld Controller
    By BOI122 in forum CNC Machining Centers
    Last Post: 04-16-2016, 05:30 PM
  4. When to upgrade controller
    By zoeper in forum Bridgeport / Hardinge Mills
    Last Post: 10-19-2006, 09:08 PM
