567,458 active members*
3,892 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Hardinge GTSP zero return button don't work
    Junior Member
    Sep 2005
    263
    Hello, this is a Harding GT SP with fanuc 18i when I try to zero return with the buttons on the panel nothing happens but G28 works, is this one of Hardinge's secret buttons that's turned off? Thanks
    Re: Hardinge GTSP zero return button don't work
    Quote Originally Posted by positiverake View Post
    Some parameters might need to be switched on.
    Junior Member
    Sep 2005
    263
    Any idea what ones?
  1. tool offset measure button don't work
    By positiverake in forum Fanuc
    Last Post: 08-31-2021, 09:54 PM
  2. Zero return does not work on a fanuc 6m
    By alfaguilar in forum Fanuc
    Last Post: 08-07-2019, 10:56 PM
  3. Zero return axis X does not work
    By truongtronghai in forum OKK
    Last Post: 02-26-2016, 10:58 AM
  4. Axis' don't return to zero - accumulating error
    By Scott Kelley in forum Servo Motors / Drives
    Last Post: 05-05-2011, 01:25 PM
  5. My Viper200 don't work now
    By freak_brain in forum Viper Servo drives
    Last Post: 07-30-2010, 04:21 AM
