600,887 active members*
2,914 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Haunyang hy01d511b motor current
    Mar 2025
    I'm trying to get a Haunyang HY01D511B configured for a 1.5kw 110v 12a spindle but I've hit some snags.
    #1 I can't set PD142 to match the motor at 12 amps. It won't allow anything over 7 amps. I'm hopeing there is an easy solution.
    #2 I'm controling it with a Duet3 6HC that has 5V PWM signal. I'm running it through a pwm to voltage converter module that has a 0-10v output. The converters voltage seems to match the rpm being requested from the Duet board but the vfd is putting out double the set rpm (exp. I turn the spindle on at 12000rpm with the duet board and the vfd puts out 24,000 rpm's)
    #3. Is it ok to run the load or neutral wire from the water pump through the relay? If so would I use FA, FB or FC?
    Any help will be greatly appreciated.
    Re: Haunyang hy01d511b motor current
    Quote Originally Posted by Alijambo View Post
    The VFD appears to be limiting the maximum current (PD142) to 7A instead of the 12A required by your spindle.
    You can check PD143 (Motor Voltage Setting) and PD141 (Motor Rated Power) settings, are they matching your motor?
    Mar 2025
    Quote Originally Posted by cncmakers001 View Post
    I have checked that 10 times. I'll see if i can get some help from haunyang. The other weird thing is the vfd will only go to 12000 but at 12000 the spindle is turning at 24000. PD 143 IS set to 2 and PD144 is set to 3000.
  1. Replies: 1
    Last Post: 03-22-2021, 01:57 AM
  2. Huanyang HY01D511B - PD142 Motor Current setting
    By Wood768dGuy in forum Spindles / VFD
    Last Post: 03-19-2021, 12:55 PM
  3. DRIVER CURRENT SETUP - MOTOR RATED CURRENT
    By kmin in forum Stepper Motors / Drives
    Last Post: 08-28-2015, 12:17 AM
  4. Haunyang VFD Spindle
    By dobrow2007 in forum DNC Problems and Solutions
    Last Post: 05-02-2012, 02:54 PM
  5. Low Current interface, High Current Motor?
    By Clackvalve in forum CNC Machine Related Electronics
    Last Post: 05-13-2010, 06:42 PM
