550,246 active members*
3,187 visitors online*
Results 1 to 14 of 14
    Jan 2022
    Have a cnc controller without PWM
    I have a cnc controller but I can't find the pwm terminal to hook up a laser diode, but in the board there is space that is written 10v please I need help will attach a picture of the China controller. All ideas are welcome
    Jan 2018
    1097
    Quote Originally Posted by Henryme View Post
    Try this:
    https://drufelcnc.com/doc/DrufelCNC_STB5100_manual.pdf
    Looks exactly the same and shows your 10v pin is the PWM type speed control and the AVI/GND are the analog (0-10) type control.
    Jan 2022
    [QUOTE=dazp1976;yes they look alike but the laser already have 12v going into it, and the controller has 10v, won't there be issue. I don't know much about electronics and electricals
    Jan 2005
    13253
    Re: Have a cnc controller without PWM
    Quote Originally Posted by dazp1976 View Post
    Try this:
    The 10v is an input for the PWM to Analog 0-10v converter
    Mactec54
    Jan 2005
    13253
    Do you need a PWM output or a 0-10v Analog? AVI & Com is a 0-10v Analog output the 10v is an input for the AVI to work.
    Mactec54
    Jan 2022
    mactec54, how are you suggesting the laser diode should be connected
    Jan 2005
    13253
    What is the laser requirements, to turn it on??
    Mactec54
    Jun 2005
    1392
    Go to cnc4pc.com and get the little PWM card that you can wire to your current card, it’s really cheap and works great
    Russ
    Jan 2022
    @mactec54, all it requires to turn on is 12dcv and a PWM
    Jan 2022
    @CNCMAN172 please do you have have any particular pwm card in mind.
    Jun 2005
    1392
    Cool Re: Have a cnc controller without PWM
    Here is a simple card, you can get matching cables this will provide the PWM signal required by most spindles, lasers, etc.
    https://www.cnc4pc.com/c41s-pwm-vari...rol-board.html
    Nov 2008
    592
    I’m confused how this card would control a laser? It’s for spindle speed control.
    This card lets you control your spindle with PWM and direction signals, as if it was an axis motor. It converts the step signal into and an analog (0-10VDC).
    Jan 2005
    13253
    Quote Originally Posted by CNCMAN172 View Post
    That is of no use what's so ever, he already has a Breakout Board that can do what this does
    Mactec54
    Jan 2022
    Thanks to everyone, I Have figure out the wiring to the breakout board.
  1. Looking for a PWM Motion Controller
    By Jrjones in forum Controller & Computer Solutions
    Last Post: 08-25-2015, 05:24 PM
  2. Enable PWM on Controller
    By John6310 in forum Hobbycnc (Products)
    Last Post: 09-22-2014, 06:11 AM
  3. PWM controller
    By sswitaj in forum General CNC Machine Related Electronics
    Last Post: 08-27-2007, 12:28 AM
  4. 3D or 2D MAXI Style Hobby CNC PWM Controller!
    By icm in forum News Announcements
    Last Post: 01-05-2005, 03:36 PM
  5. 3D/2D PIC PWM Step/Dir CNC Controller
    Last Post: 09-19-2004, 03:05 PM
