547,126 active members*
2,993 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > have you heard of this machine sx3 benchtop
Results 1 to 4 of 4
    Junior Member
    Jul 2018
    43
    I came across this comapny called axyzmachines.com looks like x2 mini mills converted. the price seems ok 3000 for the fully loaded. What do you guys think.
    Jan 2018
    946
    Re: have you heard of this machine sx3 benchtop
    I wouldn't touch another X2 for cnc with a bagepole.
    While the spindle haeads are not bad (until it stalls), the x,y table is crap!.
    Taable- Twists, vibrates, wears, all over the place, and the gib design is poor.
    For frequent use as cnc these machines are just much too light and not rigid enough.
    Nope.
    I've never seen that company before and I'd be cautious as I suspect they are probably a build to order type fly by night , though I may be wrong and I don't want to be insulting .
    Otherwise , not bad price for a complete package if it's well pieced together with a solid column . They don't provide much info at all . I'd avoid that cheap chinese control and go with mach at the least . The brushless motor is the way to go since the brushed motors go through brushes fairly quick and they burn out after a lot of use
    Junior Member
    Jul 2018
    43
    Quote Originally Posted by metalmayhem View Post
    I looks like the machine is using a solid column looks like you have the option of choosing a version of mach3, I do like the spindle motor 6000rpm bldc 1.2nm torque. I will say that i like the yokes for the axis that they are using, they seem pretty sturdy
  1. Has anyone ever heard of or dealt with a Morton Milling machine?
    By ElecEBill in forum Machinery Manuals / Brochures
    Last Post: 04-23-2014, 03:50 PM
  2. mach3profile for sx3 machine
    By ata in forum Syil Products
    Last Post: 01-29-2012, 12:27 PM
  3. Have you heard of Shining3D Crystal Laser Engraving Machine
    By shining3d in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 03-08-2011, 08:57 AM
  4. Maintenance on a sitting 1 1/2 yr old SX3 machine
    By idtkid in forum Syil Products
    Last Post: 05-22-2009, 08:44 AM
