Originally Posted by
Pasticciere
Thanks a lot for your reply, Maktec.
My spindle is 400 hz and the parameters I set are the default ones, which if you have some time, you can read in the pdf link that I posted. I was confronted by another boy, who has my own inverter and spindle, but after hours of work, he heats up very little, while mine after 10 minutes becomes very hot, so much so that he cannot touch it by hand.
I think I'll send it back to get a water spindle and I'd like to do it before it catches fire. : D
However in the case, if you want to take a look at the manual, with the default data, could you give me your opinion on the parameters?
I thank you for your availability.
