587,004 active members*
2,768 visitors online*
Results 1 to 14 of 14
    Jul 2007
    153
    Heidenhain TNC 355 wont move HELP
    Hi Guys,
    Im looking for some assistance please and would be happy to pay for professional help! PayPal etc.
    I have purchased a used Kasuga 850 Milling machine and it has a TNC355 control. I was able to install the machine and PLC parameters. The machine now starts and shows a good screen, it has the referencing sequence showing on the screen but does not move! Its like the servos and the machine has not started? No alarms nothing. Just XYZ reference on the screen. Wont move.
    I do have another machine also a Kasuga 850 only with the later TNC415B it it runs great so Im not a complete stranger to the system and Im quite handy around machines.
    Can anyone help me?
    Im in Australia. GMT +10 hours
    Sep 2012
    217
    Re: Heidenhain TNC 355 wont move HELP
    Might be a stupid question but have you managed to home the machine or nothing at all?
    Regards Bob
    Sep 2009
    99
    Hi Rotec,
    Could you share some photos of what is happening? Is there a * mark next to the axis display after you press Cycle start for referencing?
    Best regards
    JSS
    Jul 2007
    153
    Sudsy,
    Nothing at all, screen shows axis ready to reference but none will move. My other 850 has a Heidenhain 415B control and has the same Yaskawa servo drives. So I know when they are ready normally two LEDS lit.
    To me it feels like the machine has not fully started. There is no * asterisk next to nay numbers and also the fan on the spindle cooling motor is not making any noise like on the other machine.
    Jul 2007
    153
    Hi JSS,
    No * asterisk. Please take a look here I made a short video of the start-up and pics too. https://1drv.ms/u/s!AuL0GcB6FoDfgcJA...ZCMKQ?e=cy1eBC
    Thanks.
    Sep 2009
    99
    Hi Rotec,
    An observation (please correct me if I'm wrong)- in my Heidenhain controls (I have a set of TNC 426 and iTNC530s) the pass over reference axes are highlighted before the referencing is complete. Also it shows a * mark once movement starts.
    I am of the opinion there might be something wrong with your parameters or PLC program- if you have it backed up you could try transmitting it again to the machine (not sure how the PLC program transfer works for the TNC355, but the parameters I do remember backing up and transferring).
    In case if you ever need, I have a working TNC 355 control I am ready to part with- we removed it from one of our machines (we upgraded it as we were having long programs which weren't fitting in this controls memory)
    Best regards
    JSS
    Jul 2007
    153
    Quote Originally Posted by jaideepshinh View Post
    Hi Rotec,
    Best regards
    JSS
    Hmmm..... Well this machine came to me from a guy who had the same issues ie itwouldn't "pass over", he never got it working so it just sat till he got rid of it. When I got the MC I thought I'll just install all the MC and PLC parameters, but no go Oh the batteries were rotten so I replaced the entire holder and battery pack. It holds memory now.
    The original parameters for this machine were written on sheets in the manual. So we made a file and transfered to the MC via serial cable. Transfer works. Likewise the PLC parameters these were transfered in the same way.
    Is there anything that you suggest I do? The other machine is exactly the same Kasuga 850 only with a 415B control. Would the PLC parameters be the same, being the the MC is the same?
    Jul 2007
    153
    Hi Rotec,
    Best regards
    JSS
    Do you think I could try loading your TNC 355 PLC parameters to see if it moves? I know for a fact the servo drives are not ready. They appear to be in standby.
    I do not really understand how these seprate PLC modules work in the system and what they are for?
    The 415B on the other machine does not have the PLC as seperate items, so I assume the 415B has the PLC build in?
    Sep 2009
    99
    Dear Rotec,
    I do have my parameter backup, but I do not know if I have my PLC backed up. I'l check on this and share it with you if available.
    However, I would assume the PLC would've been customised to suit the machine, and may not work directly with yours.
    In the event of your control trying to give and output to the drives and the drives not being ready or not responding, the control would show a drive fault or a gross positioning error with a letter following showing the cause of the error.
    Are you able to access any other menus or is the control frozen on the Pass over reference display? Does pressing any of the other butttons give you a message saying "key has no function" message?
    When powering on do you get the message "Relay external DC 24V missing" ? I'm just trying to clue together information as to why the control would be behaving the way it is.
    Is it possible to copy a part of your PLC and display it here?
    Best regards
    JSS
    Jul 2007
    153
    Dear Rotec,
    Best regards
    JSS
    Yes all the buttons work on the control. I dont recall ever seeing "Relay external DC 24V missing".
    "key non functional" YES that is seen often.
    I'll try on get the PLC file and post it here.
    Sep 2012
    217
    That means your 24v supply isn't on or not working
    Regards Bob
    Jul 2007
    153
    Quote Originally Posted by sudsy View Post
    Cheers Bob,
    So are you saying i should be seeing "Relay external DC 24V missing". ?
    Because I never have seen this.
    I notice you are in Australia.
    If you could spare me 5 mins for a quick chat on this, I'd appreciate it.
    Paul 0428 360 100
    Sep 2012
    217
    Sorry I misread it. I thought you were getting the 24v supply message. Sent you a PM with my number anyway
    Regards Bob
    Apr 2024
    hello im new to this so don't no if anyone will reply but i have a huron NU4 146 milling machine with a Heidenhain tnc 355 i lost all parameters for it and i have managed to find some online but i don't think they are correct its gets as far as the referencing screen then does nothing so im sure some parameters are wrong it has 383 line of parameter code. any help would be great
  1. z wont move off home switch. please help
    By Jon.N.CNC in forum UCCNC Control Software
    Last Post: 08-26-2015, 04:04 AM
  2. CNC Machine wont move at all
    By OzzyNeedsHelp in forum Chinese Machines
    Last Post: 09-22-2014, 11:42 PM
  3. MDI G1 wont move
    By brokenrinker in forum Fanuc
    Last Post: 11-21-2012, 12:50 PM
  4. X,Y,Z wont move
    By Nymisis in forum Bridgeport / Hardinge Mills
    Last Post: 01-29-2008, 05:30 PM
