Re: Heidenhain TNC 530 Tool changer not in position DMG MORI CNC MILL
Originally Posted by
MACHINATORY
i had a question for the gurus here i am new to heidenhain while i was learning the control i managed to do a tool change
simple enough; it did the tool change but then i got this message alarm TC: changer not in position and it's not going away
in my instructional manual i have two ways to clear this one is through using the soft keys but the features are not available they're all gray
and the other is to use "MOD" and passcode "789" however it's not letting me in
do you guys have any experience with that? i appreciate the help.
Maybe you can try this and see if it helps.
1. Jog mode
2. Area switchover
3. Softkey 7 deckel maho
4. Softkey 7 manual operation
5. Softkey 1 tool change
6. With the keys yellow or violet, the tool changer can be moved. If it doesn't move after poking these,
7. Ref the axis. And all should work.
