600,787 active members*
4,275 visitors online*
IndustryArena Forum > CAM Software > MadCAM > hello needed with assigning directions with open curves in MadCAM
Results 1 to 6 of 6
    Apr 2014
    16
    I work a great deal with open geometries, lines that describe paths for cutting shallow peripheral grooves in 6-10mm thick acrylic.
    Can I assign orientation and direction to these geometries? Put simply, can I draw an open line and tell the tool bit to cut to the left or right of that line, and not just center? Can I then select that toolpath to offset it a small distance reversing it's direction on second pass? I don't see how where this is done. I have previously worked for decades with Alpha CAM, where this is very straightforward.
    re: hello needed with assigning directions with open curves in MadCAM
    Quote Originally Posted by 2C3D4U View Post
    You mentioned you were on AlphaCAM before, but didn’t say what you’re currently using
    Because the interface and options are very different across CAM software.
    May 2006
    346
    Yes you can cut on, or left or right of curves. And offset. But I believe offset input also will add or subtract to depth too.
    2d profiling icon is where you would do this in Madcam
    Apr 2014
    16
    Please clarify the intent of your response. My question regards something quite specific to MadCAM. If I didn't make that clear, kindly point out why you interpreted otherwise.
    Apr 2014
    16
    Thank you, but for the life of me, I don't specifically see where this is selected for. I draw a rectangle, call it my material, assign some arbitrary thickness, then draw an open curve........ok, how do I tell my tool to use my open curve as a guide line on the RIGHT side of that curve, or the left side of the curve. I don't see it. Offsetting would be great as well, with path return in the reverse direction.
    Apr 2018
    141
    Re: hello needed with assigning directions with open curves in MadCAM
    I think the comment arose because none of the text in your original post mentioned MadCAM. Yes, this thread is in the MadCAM subforum, but that is not necessarily a reliable indicator of content. Threads often get created in a less-than-optimal subforum.
    I edited the thread title to include "MadCAM".
  1. Replies: 2
    Last Post: 10-21-2024, 04:51 AM
  2. Replies: 1
    Last Post: 05-16-2018, 03:28 PM
  3. Advice needed: Madcam usability
    By Der3er in forum MadCAM
    Last Post: 11-27-2012, 11:49 PM
  4. Replies: 1
    Last Post: 11-08-2011, 05:30 PM
  5. Stepping into the CNC world...Directions needed.
    By Regalrip in forum DIY CNC Router Table Machines
    Last Post: 04-29-2010, 03:15 PM
