602,995 active members*
4,134 visitors online*
Thread: HELP !
Results 1 to 16 of 16
    Jun 2008
    262
    HELP !
    I have a laptop connected to this TB6560 Chinese stepper driver board and a NEMA 17 both of which I got off Ebay.
    When I power everything up, the LED's all light. I tried to move a motor but nothing happens. I'm pretty sure I have the motor wired right.
    After 10 or 15 minutes the motor gets rather warm.
    Any ideas as far as a quick start? Does this sound like something's bad?
    Thanks !
    i build the braces that keep american teeth straight......tick tick tick
    Jun 2008
    262
    A little research and perhaps the steppers I have draw too few amps for the driver...sound correct? anyone? anyone?
    Thanks!
    Apr 2004
    5944
    I doubt that "too few amps" is really your problem. Is your board hooked up to something that's giving the motors a signal to move? Mach3 or something else? Does this laptop have a parallel port that runs in EPP mode?
    Andrew Werby
    www.computersculpture.com
    Jun 2008
    262
    It's really weird. I got it into EPP as you said but keep getting strange things like a motor will only run occasionally and only in one direction...the Z I mean. I have another motor on the X and it doesn't do anything at all.
    Apr 2004
    5944
    It could be the laptop. Many of them, even if they have parallel ports, don't give enough voltage to the port to reliably operate a CNC machine under Mach3. Laptops in general aren't recommended for running Mach. See if you can scrounge up an old desktop computer with a parallel port and try that. If it still doesn't work, it's probably just another example of a bad TB6560 board - there's no shortage of people who have bought them and been disappointed, as you can see by entering it into this forum's search box.
    Andrew Werby
    Jun 2008
    262
    Thanks Andrew,
    For S&%#'s and Giggles I'll try the other 6560 I have and compare the crap.
    Nelson
    Apr 2004
    5944
    The other one? I never heard of anybody who'd tried one of those things actually going out and buying another one...
    Andrew Werby
    Jun 2008
    262
    So Andrew,
    I looked at Gecko's website for a 3 axis board with a printer port interface (standard connector) and didn't see one.
    Is there something similar to the 6560 but better out there?
    Thanks,
    Nelson
    Apr 2004
    5944
    Get the g-540: G540 4-Axis Motor Control It has 4 axes, but you don't have to use all 4. You can use it for a rotary table when you get one, or keep it as a spare axis for troubleshooting. Most people who replace their TB6560s with this can't believe they're running the same machine.
    Andrew Werby
    Jun 2008
    262
    I did find Probotix who have 3's Have you heard of them, are they crap?
    Nelson
    Apr 2004
    5944
    I haven't tried them myself, but looking at their 3-axis kits, everything but the most expensive one ($600+) was limited to 24 volts. That's not going to drive most 23-frame steppers at their full potential speed. The G-540 includes a built-in breakout board, and is good to 50v.
    Andrew Werby
    ComputerSculpture.com ? Home Page for Discount Hardware & Software
    Aug 2024
    3
    Re: HALP !
    Check out the back to school sale from Phomemo, who focus on the thermal printers and lead in the printing industry.
    Mar 2025
    8
    Re: HALP !
    For high-precision sheet metal fabrication and customized 3D-printed components, CTT Technology is a reliable choice. Their advanced manufacturing ensures durability and accuracy.
    Mar 2025
    8
    Re: HELP !
    From precision molds to CNC machining, ARES Precision delivers high-quality industrial solutions. Their expertise in die casting and 3D printing ensures outstanding results.
    Mar 2025
    8
    Re: HALP !
    Looking for a portable power station? JazzPower specializes in energy storage, solar panels, and home inverters, ensuring efficient and reliable power solutions.
    Mar 2025
    8
    Re: HALP !
    For industries requiring ultra-high-pressure solutions, HiLock offers top-quality connectors, valves, and sterilization equipment with precision engineering.
  1. nead halp multicam 3000
    By asitech in forum Multicam Machines
    Last Post: 10-03-2011, 11:16 PM
  2. neew halp
    By nagaraj71 in forum Australia, New Zealand Club House
    Last Post: 05-30-2009, 12:02 PM
  3. halp me to treat the 300 alarm
    By aymancom1 in forum News Announcements
    Last Post: 05-09-2009, 05:47 PM
  4. Need halp with first CNC
    By graciocues in forum Community Club House
    Last Post: 03-20-2008, 09:55 AM
