I want to buy a bldc motor driver but i am confused about the AC power input, does it convert the power to dc internally to 48v?. I have attached the pictures of the motor and driver any input is greatly appreciated
It would be better if I understood Chinese, but yes it looks like that driver takes 80-220VAC as the input. However STOP. it puts out 310 Volts , not 48 as your title suggests you need.
thanks for the reply, so I could connect 120v ac and output 320v? so a 310v motor could work?
It looks that way.
I was looking at the data that I found here.
https://imall.com/product/310V-High-voltage-brushless-DC-motor-drive-ZM-7205-can-1000W/Home-Improvement-Electrical-Equipments-Supplies-Motors-Parts-Driver/aliexpress.com/32743052334/144-2560276/en
https://www.aliexpress.com/item/32743052334.html
