504,045 active members
4,331 visitors online
IndustryArena Forum > Machine Controllers Software and Solutions > UCCNC Control Software > Help choosing the right motion controller for UCCNC + MX4660
Results 1 to 12 of 12
    Oct 2018
    17
    Question Help choosing the right motion controller for UCCNC + MX4660
    I've decided on UCCNC to run my Leadshine MX4660. To begin, I will run a DeWalt router and SuperPID until I get a dedicated 220v outlet, then I will switch to a VFD+Spindle. I will be using a Windows 10 64bit laptop. At first I nearly bought the UC100 USB but after a little more reading it seems the UC300 or UC400 are better choices for only a little more money. Opinions?
    Features I plan to use:
    3x Home switches
    3x Limit switches
    Spindle start/stop/speed control
    Touch probe (Z/corner find)
    Mist/air on/off
    Water pump on/off (If I get a water cooled spindle)
    Possibly 4th axis (5th motor - my table has slaved 3&4)
    Remote control (either Xbox or a proper pendant)
    Thank you
    Jun 2015
    853
    Re: Help choosing the right motion controller for UCCNC + MX4660
    Quote Originally Posted by ddurbs21 View Post
    3x Home switches
    3x Limit switches
    Mist/air on/off
    Thank you
    The UC300ETH has much more I/Os than the UC400ETH. It has analog I/Os too. I would get the UC300ETH because the price difference is very little for that many extra I/Os.
    Mar 2003
    34495
    If everything is wired to the MX4660, then the UC400ETH is really all you need.
    But I also usually recommend the UC300ETH, as it's only $25 more.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    I am using the UC300eth, I also have a MX3600 and G540 in my controller. It works quite well.
    I am on W10. You can easily do all the things you want to do with that setup.
    Oct 2018
    17
    That's 3 votes for the UC300. Does it typically include the ribbon cable to connect to the MX? The websites for these products leave a lot to be desired. I'll probably order from CNC4PC's Amazon store since I need to get a load of things from there anyway.
    Mar 2003
    34495
    No cables are included.
    Gerry
    Oct 2018
    17
    Thanks fellas
    Oct 2018
    17
    I sprung for the UC300ETH + 5LPT and so far everything works exactly how it should. I've wired in homing switches and configured them to also act as Limit (-). My Z home (0) is at the top and as it goes down the numbers are in the negatives. I can safely run my Z down to -9.4in with about 0.1in before hard parts touch. I see where to set Safe Z Height but it seems to only accept positive values - entering "-9.4" changes the value to 0. How do I stop my Z from crashing? Obviously I can add another switch, but the home/limit is already set as the Limit (-) and since this maximum is a value less than 0, it wouldn't make sense to me that the new switch could be considered Limit (+).
    Mar 2003
    34495
    Set up softlimits for the Z axis, with the MIN at -9.4.
    SafeZ in UCCNC is in Work Coordinates, and is only really used with Run From Here, as a safe height above your table.
    Gerry
    Oct 2018
    17
    I see, thank you. I suppose that means I can set the soft limits for the X/Y to zero. I cut my first spoilboard bolt-down holes tonight and I'm really happy. Then I guess I'll need to level and tram. So exciting.
    Oct 2018
    17
    Got everything purring along. Added a homemade Z-probe and modified the M31 macro, added some LED lighting and a bunch of 1/4-20 T-nuts to the underside of the spoilboard. UCCNC has made me have to look hard for some answers, but as I spend more time with it I better understand what it's doing and why it works that way. Next I want to spend some time in the screen editor removing all the things I don't want like CCW spindle control, extra axis DROs, etc.
    Mar 2003
    34495
    If you have any questions, just ask here, or at CNC Drives UCCNC forum.
    Gerry
  1. Replies: 8
    Last Post: 04-13-2018, 08:48 PM
  2. Choosing motors, drivers, external motion controller - help please
    By secretspy in forum General CNC Machine Related Electronics
    Last Post: 12-14-2017, 09:56 PM
  3. Choosing a motion controller
    By spangledboy in forum Controller & Computer Solutions
    Last Post: 03-31-2013, 11:07 AM
  4. Choosing Shafts for linear motion
    By Power_user_EX in forum DIY CNC Router Table Machines
    Last Post: 06-15-2012, 05:36 PM
  5. Choosing linear motion system
    By Jesse B in forum DIY CNC Router Table Machines
    Last Post: 01-11-2010, 01:54 AM
