529,726 active members*
3,804 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Help me identify this collet system
    Oct 2005
    15
    Please help me identify this splindle tooling system
    a)
    This spindle is a Colombo RV90.2 SB. Spindle taper look like MT2 but it is a blind hole. Nut have a threaded hole at the bottom.
    Attachment 450162
    Attachment 450164
    b)
    What it the use of that threaded washer that I have unscrew ? Does it mean that the MT2 socket can be removed ? I can't find an exploded part list of that spindle. Someone can help ?
    Attachment 450166
    Jan 2005
    11544
    Re: Help me identify this collet system
    Quote Originally Posted by digit23 View Post
    a)
    Attachment 450162
    Attachment 450164
    b)
    Attachment 450166
    Normally the RV-90 spindles take an ER25 collet that may be the wrong nut someone has put on your spindle, check the angle and the diameter of the spindle nose, it also could be some special that someone ordered from Colombo, does not look in very good shape for a highspeed spindle
    Mactec54
  1. to identify good quality laser system from China
    By CST in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 12-28-2011, 04:34 AM
  2. Need to identify Ozito collet
    By allistar in forum DIY CNC Router Table Machines
    Last Post: 12-19-2011, 09:34 PM
  3. R8 collet and TTS system
    By FandZ in forum Uncategorised MetalWorking Machines
    Last Post: 05-09-2010, 07:42 PM
  4. Identify this collet
    By innova in forum Uncategorised MetalWorking Machines
    Last Post: 05-21-2009, 04:20 PM
  5. Where to buy bits & collet system
    By barkster in forum DIY CNC Router Table Machines
    Last Post: 12-15-2008, 05:16 AM
