Hi, my cnc has went down and I need a wee job done. Some engraving on 5mm acrylic. I can supply the acrylic. It's 4 panels about 210mm by 200mm. email me on mattstenhouse@outlook.com if you are interested.
I am in the UK. I can supply the file in any format. *.ai *.eps *.dxf *.pdf or if you want the *.tap file then no prob it's only a 90 v carve bit and a 3mm end mill.
Matt
