510,124 active members
3,205 visitors online
IndustryArena Forum > GENERAL MANUFACTURING PROCESSES > MILLING > HELP NEEDED Converting G Codes To MCodes
    Sep 2019
    Hi All
    Can anyone help me?
    My Cam program will only output G Code but my control (Heidenhain 155) will only accept M Code.#
    Is there a way around this i.e. an conversion program.
    many thanks
    Nov 2007
    182
    Quote Originally Posted by WOBBLER View Post
    Hi All
    Can anyone help me?
    many thanks
    Let me try to explain g-code and m-codes....ok 1st m-codes are for turning on a function like a coolant pump or turning I off or turning on a spindle or there are m codes that turn them both on at the same time ......
    Now g-code ...g code tells the machine where to go to start cutting go - rapid , or g1 feed or even turning on a canned drilling cycle like g83, or g81 this is for fanuc controls for yours this is a sample program I found on the site
    0 BEGIN PGM 12345678 MM
    1 L M09
    2 L M05
    3 TOOL CALL 03 Z S15000
    4 L M06
    5 L M03
    6 L X-51,000 Y+4,748 R0 F9999
    7 L Z-5,000
    8 L Z-13,320 R0 M08
    9 L Z-18,570 R0 F1500
    10 L X-51,181 Y+4,472 R0 F3000
    11 L X-51,341 Y+4,278 R0
    12 L X-51,509 Y+4,115 R0
    13 CR X-51,858 Y+3,875 R+1,774 DR- R0
    14 CR X-52,259 Y+3,736 R+1,448 DR- R0
    15 CR X-52,698 Y+3,728 R+1,315 DR- R0
    16 CR X-53,232 Y+3,925 R+1,450 DR- R0
    17 CR X-53,538 Y+4,157 R+1,859 DR- R0
    18 CR X-54,000 Y+4,748 R+2,454 DR- R0
    2005 CR X-68,438 Y+16,043 R+1,592 DR- R0
    2245 L X-34,194 Y+15,929 R0
    2246 CR X-34,177 Y+15,531 R+1,592 DR- R0
    2247 CR X-34,264 Y+15,087 R+2,005 DR- R0
    2248 L X-34,352 Y+14,851 R0
    2249 L X-34,500 Y+14,557 R0
    2250 L X-42,872 Y+0,055 R0
    2251 L Z-5,000 R0 F9999
    2252 L M09
    2253 L M05
    2254 STOP M30
    2255 END PGM 12345678 MM
    Anyway I hope this helps
  1. Advice Needed- Considering converting Japanese Toolroom lathe to CNC
    By C&Me in forum Vertical Mill, Lathe Project Log
    Last Post: 01-09-2017, 08:57 PM
  2. Mcodes for Pallet Recognition
    By InfamousDunkie in forum Haas Mills
    Last Post: 05-19-2009, 12:28 AM
  3. Mini Mill CNC converting info needed.
    By Oldboy in forum Benchtop Machines
    Last Post: 12-13-2007, 12:53 AM
  4. MCodes & Slow Down etc
    By matthewd in forum General CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-15-2007, 04:37 AM
  5. Needed G-Codes For Lost Technology
    By CAMCRASH in forum G-Code Programing
    Last Post: 03-12-2006, 04:59 AM
