585,982 active members*
4,644 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Help Needed? Keep losing ESS due to Power cycling on and off randomly
    Nov 2019
    11
    Like the title says. Running an Avid PRO4848 with Nema34 - Yesterday as I was homing the machine, I heard a click come from the box and the machine stopped. Got the lost ESS error. Power cycled everything and was jogging the machine around and I hear a slight click inside the controller box again and loose connection again. It's the control system, once it clicks off it will turn back on again for a few mins then click off randomly again all while I am just staring at it. If it clicks off and I tap the controller box it powers on again. My 220v running to the other box never shuts off.
    Seeing as it's Sunday night, was curious what thoughts might be? Machine is about 6 months old. Running Mach 4 on a windows 10 PC
    Nov 2019
    11
    Re: Help Needed? Keep losing ESS due to Power cycling on and off randomly
    ***FIXED***
    Quick update. Reached out to AVID CNC first thing in the AM. Excellent service as always.
    Solution: Lose wire on the power switch coming into the control panel. Fixed in 2 mins. My kind of fix!
    Just wanted to update this thread in case another user encounter this issue they can check their connections!
    - Ryan
  1. Problem. Losing power (strenght) when set to more than 60% power.
    By martin_av in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-13-2020, 01:06 AM
  2. Z-Axis Randomly losing its mind
    By Rfergman in forum Uncategorised WoodWorking Machines
    Last Post: 02-12-2019, 06:00 PM
  3. Losing power
    By moti666 in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 04-20-2018, 01:46 PM
  4. Homing position offset after power cycle (happen randomly)
    By Gerub in forum Servo Motors / Drives
    Last Post: 01-04-2017, 10:53 AM
  5. machine cuts power randomly
    By Lethrahn in forum Gecko Drives
    Last Post: 02-27-2015, 01:03 PM
