587,004 active members*
2,768 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > HELP! PC and HD died. rebuilding system. Having troudle gettinh the Z axis auto zer
    Sep 2003
    1472
    SYSTEM:
    Mach3, ESS SmoothStepper, C25 BOB.
    Originally I installed Z axis auto zero and it ran fine.
    After getting my system running again I tried to install it again and cant get it going again.
    I connect two wires to my BOB, to input pin 15 and the other wire to Ground.
    In Ports and Pins i set PROBE active, Port 2 (because its going to the BOB) PIN 15 and set to ACTIVE.
    Save and shut down and restart
    Test settings by touching the two wires together when in DIAGNOSTIC, the digitize light is already lit before I touch them together, an stays lit when they touch.
    There are only two wires connected to the BOB, pin 15 and Ground.
    what am I doing wrong?
    Theres something amis with CNCZONE I should get a email notice when someone replies but i dont??????
    Sep 2003
    1472
    Re: HELP! PC and HD died. rebuilding system. Having troudle gettinh the Z axis auto
    testing to see if i get a email notice?
    You can open a ticket in our website and we will give you a hand with this:
    https://cnc4pc.com/contact
    Arturo Duncan
    https://cnc4pc.com
  1. Z axis died
    By jackgiz in forum Dynomotion/Kflop/Kanalog
    Last Post: 04-29-2021, 04:46 AM
  2. Rebuilding my Z axis and have quesitons
    By nekidfrog in forum DIY CNC Router Table Machines
    Last Post: 06-16-2014, 01:11 PM
  3. We are rebuilding a 600 watt Raytheon GS-600 CO2 system...
    By scrat242 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-24-2011, 09:55 PM
  4. Series 1 Y-axis died
    By JH-Q in forum Bridgeport / Hardinge Mills
    Last Post: 03-28-2010, 10:17 PM
  5. BP Series 1 - Z axis power transistor died again!?!?!
    By bbuonomo in forum Bridgeport / Hardinge Mills
    Last Post: 02-16-2009, 03:46 PM
