525,618 active members*
2,454 visitors online*
    Help problem with lathe threading. Siemens 808d turning
    I have owned this lathe for just over a year, and was trying to find a good PP for it. All was fine until I came to the threading cycle. I just could not get it to thread. So I went to the controller (Siemens 808d) and entered the Cycle 99 and then ran it. At 10 RPMs I could the threading tool would go to correct threading depth then rapid to the end of the cut and start the cycle again. I am new at CNC so I don't have a lot to draw on. I was threading with it about 2 month ago and it was fine. I even took the same post and ran it again and got the same results. Have any ideas?
    Feb 2011
    301
    Re: Help problem with lathe threading. Siemens 808d turning
    can you post the program for the threading cycle
  1. Post processor Solidcam / Siemens 808D turning
    By blaine.neal in forum Post Processor Files
    Last Post: 12-27-2019, 07:37 AM
  2. Post Processor for Siemens 808D lathe?
    By NJC in forum Autodesk CAM
    Last Post: 01-21-2018, 02:13 AM
  3. Replies: 0
    Last Post: 11-19-2015, 02:23 PM
  4. Siemens 808D - compatible CAM
    By hacklordsniper in forum SIEMENS Sinumerik CNC controls
    Last Post: 09-05-2015, 11:27 AM
  5. CNC Lathe : OD threading turning = thread entry burr problem
    By ghettosled in forum General MetalWork Discussion
    Last Post: 10-02-2009, 07:26 PM
