502,264 active members
7,153 visitors online
Results 1 to 5 of 5
    Apr 2008
    4
    Help! PVC Letters Curve not right
    I have Mach3 running in a computer with windows 7 and a UC100 adapter for USB to the db25 pin on the router
    I use to the CNC to cut PVC letters, my problem is that the on the some part of the letter where a curve is it just go strait
    Attachment 424064Attachment 424064Attachment 424064
    Junior Member
    Jun 2010
    3765
    Re: Help! PVC Letters Curve not right
    We KNOW that Mach3 can do that, so I suspect your problem is backlash in the Y axis.
    Cheers
    Roger
    Sep 2005
    1547
    Is this a homemade router you designed or a commercial built model? It could be a number of things, have you used it before and it was fine or is this your first project?
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router
    Jan 2005
    10006
    Quote Originally Posted by rcs1010 View Post
    The first thing to do is to check the drawing as most fonts use sort straight lines, I redraw the font using a radius where the straight lines are, or find another font that has the look you want if you can't redraw it
    Mactec54
    Junior Member
    Jun 2010
    3765
    Very good point! Especially if the original outlines were for a smaller size.
    The thing to do would be to try carving a real circle, using G2/G3 commands.
    Cheers
    Roger
  1. Track lines between letters letters when laser engraving
    By notselrach in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 11-02-2015, 12:38 AM
  2. Engraving/using letters Help
    By machine121 in forum GibbsCAM
    Last Post: 09-01-2015, 11:33 PM
  3. Curve Side on profiling operation - "on curve"
    By Gsmcelwee in forum MadCAM
    Last Post: 09-11-2014, 10:20 AM
  4. Letters, Letters & Letters
    By Joe Crumley in forum General Signmaking Topics
    Last Post: 11-20-2011, 03:46 AM
  5. dxf letters help
    By soundoffaudio in forum General Metalwork Discussion
    Last Post: 01-12-2011, 06:07 PM
