585,925 active members*
3,406 visitors online*
IndustryArena Forum > Material Technology > Glass, Plastic and Stone > Help selecting diamond coated burrs for cutting glass
    Aug 2006
    37
    I need to cut a profile of about 34 linear inches around an ovoid in 3/16" mirror glass. I had heard of using diamond coated burrs with lots of coolant and a slow speed. So I tested it and it works with only very, very small micro fractures on the edge. Question though, is where to get high quality burrs as those that I have are the cheap asian type from a kit of several. I looked in MSC and couldn't find anything that stood out. I don't want to have to worry about the burr failing during the cut.
    Thanks, I haven't been here in a long time...
    Mar 2019
    12
    Re: Help selecting diamond coated burrs for cutting glass
    Try scomac.
  1. Replies: 0
    Last Post: 08-28-2014, 12:10 PM
  2. Sources for long-shank Burrs for foam cutting?
    By Deltic_Engine in forum Material Machining Solutions
    Last Post: 06-28-2012, 02:07 AM
  3. Solid Carbide And Coolant Through Diamond Like Coated Drills
    By CDTooling in forum News Announcements
    Last Post: 09-08-2010, 06:31 PM
  4. 1/4" dia. diamond coated files?
    By SkipW in forum Want To Buy...Need help!
    Last Post: 11-25-2009, 02:59 PM
  5. DIAMOND BITS for glass engarving
    By metalikha joel in forum MetalWork Discussion
    Last Post: 07-28-2007, 04:03 AM
