504,500 active members
3,571 visitors online
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Help system data save system files Fanuc 21M
    Jun 2019
    Does anyone know how to save system files such as ....NC BASIC, NC1 OPTN, DG
    SERVO, PMCOBAS, OPTLANG, LR BASIC, and
    PMCBBAS. when i try to save it says file protect Help
    Apr 2009
    1159
    Re: Help system data save system files Fanuc 21M
    Boot up with right most and 6th (from left) softkeys pressed.
    Jun 2019
    Thanks with keys 6 and 7 keys pressed at power up I could back up SRAM, not the system files, it would give a file protect error. Found out if you press keys 1 and key 7 at power up, it would take you to an advance menu which would then let you copy the system files
