hello again guys ... i got the ring made...and took a guess with the width of the slot... any body have any advice...maybe if you have the same kinda setup..the problem is that above 800 rpm or so, the rpm readout becomes erattic and the rpm climbs and keeps climbing until i hit estop..i have done spindle calibrate yet as i want to get a reliable rpm readout first..
the ring is 3 inches in diameter ...the slot is about 20mm wide....if you have a similiar setup.... my rpm maxes out at 10500...but ive decided to to only run at 8500..thats plenty.. maybe you could help me out with the following
1. how wide should the slot be
2. index debounce setting..
i saw a document withe recomendations on the width of the slot but i cannot find or remember where
