535,445 active members*
3,007 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Help with how to wire touch plate to a CNCEST 3040T CNC router with parallel port
Results 1 to 5 of 5
    Jan 2016
    3
    I have a CNCEST brand 3040T CNC router using Mach 3. It uses a parallel port interface. I'd like to incorporate a Z Axis Zero Touch Plate. Its a 4 axis model so the additional socket in the second picture is used for the 4th axis. Does anyone have one of these that has connected a touch plate? How did you do it? Th efirst picture shows the guts inside the control box. Power supply is off to the left.
    Thanks for the help.
    Chris
    Apr 2005
    227
    Re: Help with how to wire touch plate to a CNCEST 3040T CNC router with parallel port
    Do you have any documentation for the control box?
    If not, ask seller to send it to you.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Jan 2016
    3
    No documentation. I'll try to get in touch with them.
    Jan 2016
    3
    No luck getting hold of CNCEST. What a waist of time. Does anyone have a manual, or scan of one for this beast?
    Thanks.
    Chris
    Nov 2007
    303
    Quote Originally Posted by cvuxton View Post
    Thanks.
    Chris
    I have a 3040t but no 4th axis pm me with email I will scan mine and send it. Warning it is useless and unless u can understand Chinenglish it is very hard to make heads or tales of it ...you are gonna need to take some pics of the bob( breakout board ) does it look kind of like this Attachment 456720
  1. Z2 Height Touch Plate w/o spindle wire
    By TTalma in forum DIY CNC Router Table Machines
    Last Post: 04-11-2018, 01:07 PM
  2. Need Help! Trying to wire up a zero touch plate.
    By Junior37076 in forum Commercial CNC Wood Routers
    Last Post: 08-18-2016, 11:04 PM
  3. How do I wire a touch plate for the 2010 Screenset?
    By offthewall in forum Screen Layouts, Post Processors & Misc
    Last Post: 02-03-2014, 05:38 AM
  4. touch plate with center finder port n pin
    By DanOSB in forum Mach Software (ArtSoft software)
    Last Post: 12-21-2009, 07:56 PM
  5. Parallel Port Wire Length?
    By Sanghera in forum General CNC Machine Related Electronics
    Last Post: 10-27-2004, 05:11 AM
