537,559 active members*
3,168 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Help with minor change to post
    Jan 2021
    I am using Mastercam 21, and I changed my post but its not doing exactly what I wanted. I changed the NC output so that feeds output as "F#" instead of just "F" because I want them to be macro controlled. Now the issue is the decimal point at the end of the F command is not the correct syntax for my fanuc machine. I have changed the code on the line to 4 so that it is an integer, but now my issue is that only changes the first 2 F commands in my NC file, the rest of the F's still have a decimal.
    How can I change my post so that all my F's don't have a decimal instead of just the first 2.
    Thank you
    Feb 2021
    3
    Re: Help with minor change to post
    Go to the fmt statements
    Change the global output.. post blocks plin, pcirout are affected
  1. TNGv2 Minor UI glitch
    By theRat in forum PlanetCNC
    Last Post: 01-28-2020, 12:44 AM
  2. minor contactor issue
    By btboone in forum Tree
    Last Post: 04-05-2012, 12:36 AM
  3. Contour Minor
    By DeltaEv0 in forum Uncategorised CAD Discussion
    Last Post: 04-06-2011, 12:45 PM
  4. I want a minor change to my 1024.set file
    By jestism in forum Tormach Personal CNC Mill
    Last Post: 01-17-2010, 06:58 PM
  5. Atom Minor Mk III
    By dcencer in forum I.C. Engines
    Last Post: 08-20-2007, 01:22 AM
