585,589 active members*
3,706 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > HELP! Z axis on lathe moving more than readout position
    Aug 2015
    Hello,
    I have a Nakamura-Tome Slant I lathe with a Fanuc 11TE system and the Z axis is moving more than it should.
    I machine to a depth of 3.14 and it cuts 3.165 deep instead.
    I put an indicator on it and for every .01" on the position screen, it actually moves .0106" . for .03" on the position screen, it actually moves .0315"
    What do I need to do to make this correct?
    Thanks in advance for all the input.
    Apr 2017
    28
    Re: HELP! Z axis on lathe moving more than readout position
    may need to replace the ballscrew.
  1. Moving to a Machine position...
    By Tancuda in forum Fanuc
    Last Post: 08-05-2015, 10:01 PM
  2. Replies: 4
    Last Post: 09-06-2013, 01:14 PM
  3. Code moving to z position before xy
    By richiegore in forum MadCAM
    Last Post: 12-16-2010, 05:07 PM
  4. Newall C80 readout on Hardinge HC Chucker Lathe
    By HelicopterJohn in forum Hardinge Lathes
    Last Post: 05-07-2010, 10:52 PM
  5. Position Error Readout Ranges
    By jon_fallon in forum Fadal
    Last Post: 04-27-2010, 09:49 PM
