578,963 active members*
7,878 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > Hitachi Seiki Ht23S2 keypad stuck
Results 1 to 6 of 6
    Nov 2023
    4
    The AB12C-0043 main keypad is constantly beeping as if a key is stuck. Keypad and Function keys lock up.
    This is happening sporadically but now seems to be a constant issue. Any ideas what is causing this issue?
    This machine has the Multi-control as well for reference.
    Dec 2009
    535
    Re: Hitachi Seiki Ht23S2 keypad stuck
    Many times the little metal bracket that does the clicking breaks, it’s possible it fell off and is now completing the circuit continually. Is your keypad in good condition?
    Nov 2023
    4
    I have taken it completely apart. All keys are working properly. I can turn the machine on and sometimes it will start beeping immediately while other times i can get through the power up sequence and then it starts beeping and the keys are now nonfunctional. It has happen before while running the machine and i would shut it down completely then restart and it would go away. It is not going away this time and i am stuck
    Nov 2023
    4
    I am now getting an SP 23 error message
    Dec 2009
    535
    Those boards go bad very often. That is likely the issue if it’s physically ok
    Nov 2023
    4
    I ended up disconnecting the power from the SP-23 board located on side of monitor cage. I powered up the machine and then connected power to board again. This resulted in an ACGC SYNC ERROR. I fixed that error and powered down then back up again. All is well. We shall see how long this last. So far it's been five days of running without issue.
  1. HELP HITACHI SEIKI HT-23SIII Seicos NC stuck with 5 ALARMS
    By rfonsecajr in forum General CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-06-2022, 12:28 PM
  2. HELP HITACHI SEIKI HT-23SIII Seicos NC stuck with 5 ALARMS
    By rfonsecajr in forum Controller & Computer Solutions
  3. Keypad stopped working on Hitachi Seiki Lathe
    By docdesigns in forum Hitachi Seikis
    Last Post: 11-29-2016, 09:18 PM
  4. hitachi Seiki VK45 tool changer stuck
    By Dancy in forum Uncategorised MetalWorking Machines
    Last Post: 12-26-2007, 02:06 PM
