527,859 active members*
1,456 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > Hitachi seiki vm40 spindle wont go over 3000rpm
Results 1 to 4 of 4
    Hi i hope some one can help. I have a Hitachi seiki vm40 with Seikos control, it has Mitsubishi 6000rpm spindle motor and drive. It will not go above approx 2900rpm. No alarms, no load on spindle, no noises. Control working perfectly otherwise. Can some one give me some helpful advice?
    Thanks in advance,
    Craig.
    Dec 2019
    18
    Re: Hitachi seiki vm40 spindle wont go over 3000rpm
    I’m using big drill on my late I often get alarm 3100 (servo alarm) and 3141 (axis overrun protection x axis) it always happens when drill is going back to zero point during g00 z20.0m09 G97 g30 u0 w0
    Kodi nox
    Jul 2020
    Do you have a winding's selector? Sounds like you are not getting into the H windings? Also, check the drive parameters? Did this happen all of a sudden?
    Quote Originally Posted by Craig1971 View Post
    Thanks in advance,
    Craig.
    If it is using frequency inverter, then you can check its setting for highest speed, is it match with 6000rpm speed?
    Or you can check the electronic gear ratio setting.
  1. Hitachi Seiki VM40 Alarm
    By Bosto in forum General Off Topic Discussions
    Last Post: 11-11-2019, 09:33 PM
  2. hitachi seiki vm40 seikos m2
    By bosko in forum General Off Topic Discussions
    Last Post: 10-22-2018, 12:52 PM
  3. hitachi seiki spindle wont turn on
    By docdesigns in forum Hitachi Seikis
    Last Post: 09-19-2018, 08:59 AM
  4. Hitachi Seiki VM40 seicos 2
    By bevins in forum Hitachi Seikis
    Last Post: 05-08-2013, 04:06 AM
  5. hitachi seiki vm40 error 141
    By Mousie in forum General CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-15-2009, 10:10 AM
