496,342 active members
7,328 visitors online
Page 1 of 3 123
Results 1 to 12 of 31
    Jonatanw
    Guest
    Homing with proximity and encoder pulse
    To increase accuracy i´m thinking of using both proximity sensors and the encoder pulse.
    I have UC300ETH card and controls it through UCCNC. The encoder of my servo is able to send a pulse at origin point every rotation.
    My idea is to home firstly to the proximity sensor at a determined speed and when hit the axis backsoff at a slow speed until the encoder pulse is hit.
    That would make a really accurate system. Whats your thoughts?
    Does anyone know how i can edit the home sequence in uccnc?
    Mar 2003
    33097
    Re: Homing with proximity and encoder pulse
    I don't think the homing is accessible in UCCNC, so it may not be possible.
    There used to be a commercially available board to accept both signals and send the appropriate signal to the software, to allow this in Mach3 back in the day.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Oct 2005
    767
    There is a MACRO solution to that function in UCCNC. You might want to ask about it over at the UCCNC Forum.
    (;-) TP
    Oct 2004
    217
    You can also do a messy wiring where you pass the encoder signal through a switch, then feed it into the breakout board.
    Arturo Duncan
    [url]https://cnc4pc.com[/url]
    Jan 2005
    9040
    [QUOTE=Jonatanw;2260844]Hi,
    Does anyone know how i can edit the home sequence in uccnc?[/QUOTE]
    Even if you could you would not use both The Encoder index Pulse is the most accurate, if your control does not support Encoder feed back, then that is not going to happen, so you would use just the Proximity switch for Homing, and that is normally ok for most users, your work X0 Y0 Z tool zero work offsets are what controls your cut part accuracy
    Mactec54
    Oct 2005
    767
    Hiya MACTEC. You use teh proximity switch position to get you into position to do teh encoder index homing. I did it in Mach3 and UCCNC with a simple macro solution.
    Just a thought, (;-) TP
    Jun 2015
    637
    [QUOTE=mactec54;2261250]Even if you could you would not use both The Encoder index Pulse is the most accurate, if your control does not support Encoder feed back, then that is not going to happen, so you would use just the Proximity switch for Homing, and that is normally ok for most users, your work X0 Y0 Z tool zero work offsets are what controls your cut part accuracy[/QUOTE]
    Mach3 and UCCNC does not support encoder feedback to the control, but you can still do homing to an index, but you need to code the logic yourself.
    You can for example home to the home switch and then change the home pin to the index input using code and home again to that. You can do all this in mach3 and uccnc too with scripts.
    Oct 2005
    767
    Actually both Mach3 and UCCNC support a FORM of encoder feedback. You can use encoders to track position of an axis and it is displayed in both controllers. IF you start out homing teh axis accurately then zero teh encoder counts you can always return back to Machine Zero based on the encoder counts and rezero teh Machine Home position if needed.
    Jonatanw
    Guest
    [QUOTE=vmax549;2260934]There is a MACRO solution to that function in UCCNC. You might want to ask about it over at the UCCNC Forum.
    (;-) TP[/QUOTE]
    I can´t seem to find that macro on the Uccnc forum. There is a thread about smart home but it seems to not cover the "back off to index pulse" part.
    Jonatanw
    Guest
    [QUOTE=vmax549;2261410]Hiya MACTEC. You use teh proximity switch position to get you into position to do teh encoder index homing. I did it in Mach3 and UCCNC with a simple macro solution.
    Just a thought, (;-) TP[/QUOTE]
    Any chance i can have a look at the macro you used and see if that can be applied to my machine to?
    I have not created any macro yet so i don´t really know where to start.
    Mar 2003
    33097
    [QUOTE=Jonatanw;2261560]I can´t seem to find that macro on the Uccnc forum. There is a thread about smart home but it seems to not cover the "back off to index pulse" part.[/QUOTE]
    Unfortunately, someone deleted all of their posts there, which made a lot of the macro threads there useless.
    Gerry
    Jan 2005
    9040
    Yes that's the normal way it is done the axes hits the Homing Switch Proximity or what ever, and then backs up to find the Encoder Z Pulse ( Encoder index Pulse )
    But if the Control can't read or have Encoder feed back connection, there is no point even with a Macro
    Mactec54
Page 1 of 3 123
  1. Need help: Z axis proximity sensors and homing setup
    By Kosh in forum Mach Software (ArtSoft software)
    Last Post: 01-19-2016, 04:14 AM
  2. Bridgeport MDI homing pulse
    By DHG in forum Bridgeport / Hardinge Mills
    Last Post: 10-01-2015, 04:10 PM
  3. Homing using limit and encoder index pulse?
    By purple_jeep in forum Dynomotion/Kflop/Kanalog
    Last Post: 07-09-2013, 06:09 PM
  4. proximity sensors for homing or thc?
    By Wolfesmetalfab in forum General CNC Machine Related Electronics
    Last Post: 12-03-2008, 07:30 AM
  5. Replies: 0
    Last Post: 07-22-2005, 09:51 AM
