559,951 active members*
2,628 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Horizontal Mill help
    Jul 2005
    1646
    Hello all
    i was wondering if someone had a MasterCam sample file that is of a part on a horizontal mill ( usually do the lathes) ... i am trying to learn to program the horizontal we have here and am working figuring out having 4 sides to program B0 B90 B180 etc etc
    i just need sample file for a machine that has this so i can look at how its done, the mastercam training videos don't show this, it can be a simple part
    i am not sure if i use viewsheets for each side or if its just done with toolpath groups
    any help is always appreciated
    Flies Fast
    Dec 2008
    2889
    Re: Horizontal Mill help
    1st and best advice is to understand your initial setup
    ... a 3 axis vertical machine, the part face is placed in the TOP plane, so the FRONT, BOTTOM planes fall correctly. You may have to create a new BACK plane, as it may be up-side-down( depends on post).
    ... a horizontal is different, the TOP WCS is the view you see looking from the Y+ position. The B0 face is the FRONT face. So B90 makes the RIGHT face, B180 is BACK, B-90(B270) is LEFT face.
    If you use a different co-ord system for each face, there are methods to assign a system to each view
    If you are programming only the TOP face, you can have the part face set as TOP WCS
    Each toolpath requires "planes" to be set before selecting cut parameters
    NOTE... make sure that tool has retracted BEFORE any index (B) moves... spindle crashes on a horizontal can be expensive.
    Take little steps, it takes time
    Remember... WCS is always TOP, C & T plane is what you want the tool to address.
  1. Horizontal Mill
    By MortyNTenon in forum Milltronics
    Last Post: 04-30-2018, 03:44 AM
  2. B axis for horizontal mill OM
    By nabil_elbadri in forum Fanuc
    Last Post: 12-09-2016, 08:38 AM
  3. How to bore and mill a hole on Horizontal Boring Mill
    By SatishNaik in forum News Announcements
    Last Post: 11-11-2013, 07:29 AM
  4. How to drill and face mill using table type horizontal boring mill
    Last Post: 10-09-2013, 01:10 PM
  5. G0727 horizontal mill
    By lilguy in forum Benchtop Machines
    Last Post: 11-24-2012, 12:34 AM
