589,422 active members*
5,620 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Hotwire Cutter Question (DXF Problem)
Results 1 to 5 of 5
    Jul 2024
    3
    Hello there. So i buildt myself an hotwire cutter.
    Now i build it larger then needed.so i have space for future proejcts.
    Now i would like to create a DXF or something else that shows the full workarea.
    The standart size plates i need. and what the machine should cut.
    Like so
    As you can see in the pictures i would only like to cut the blue lines.
    Red and Black would be only there to define Workspace and outlines.
    The prolem is the machine want´s to cut every line.
    Is there any way to get this to work ?
    Feb 2011
    146
    Re: Hotwire Cutter Question (DXF Problem)
    if you export all to g-code then eeverything will be cut. Simpe as that. So first: draw in proper coordinate sys (x, y, z), then export only desired line to g-code and position shoud be taken from drawing (depends of program you draw and-or shoud be adjusted somewere).
    Suggesting that prolongate the end and starting point like 5-10mm so wire will come out of the material.
    Jul 2024
    3
    Would you have any suggestion for a Programm that works like you said ?
    And thanks for the Input
    Feb 2011
    146
    you can use F360 or anny other program you familiar with. Only important thing is that exact position must be stored in dxf file.
    Jul 2024
    3
    Thanks so i have to get to know how to save the exact position. Tried some things but didnt work.
  1. MEGAPLOT C848 CNC HOTWIRE FOAM CUTTER
    By blockwire in forum For Sale Only
    Last Post: 05-03-2021, 05:18 AM
  2. 4 axis cnc diy hotwire cutter (raspberry pi?)
    By bryanlorenzo79 in forum CNC Wire Foam Cutter Machines
    Last Post: 08-27-2016, 03:40 PM
  3. NewCnc hotwire cutter 0 footprint
    By alans in forum News Announcements
    Last Post: 05-17-2012, 09:11 PM
  4. Solidworks to HotWire cutter?
    By jlcortes in forum CNC Wire Foam Cutter Machines
    Last Post: 12-26-2010, 05:19 AM
  5. Hotwire Foam Cutter
    By paprjam in forum Casting Metals
    Last Post: 03-23-2009, 05:45 PM
