600,988 active members*
3,113 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > How edit and save a parameter change Mitsubishi control
    Nov 2014
    Need Help to edit parameter on Mitsubishi control
    Can someone please remind me of the steps to edit parameters on a Mori NLX with a Mitsubishi control. I only remember to set the machine to MDI and press SYSTEM, then SETUP. I also don't remember if I set the key to Edit etc. Thanks
    Mar 2025
    Re: Need Help to edit parameter on Mitsubishi control
    For find solution for this problem, visit below show the YouTube link;
    https://youtu.be/J_ETpc2LZyo
  1. OSP 5000 wont save parameter changes
    By GITRDUN in forum Okuma
    Last Post: 10-11-2013, 06:15 PM
  2. Leadwell w/Mitsubishi control won't change tools - help!
    By SRT Mike in forum Uncategorised MetalWorking Machines
    Last Post: 09-17-2013, 05:06 AM
  3. Parameter files for Dynamechtronics DM 4500 with Mitsubishi M3 control
    By Marty_Escarcega in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-11-2012, 02:15 PM
  4. edit key offset parameter
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-28-2009, 03:54 PM
  5. Parameter to change for barrier control on a T2 lathe
    By nervis1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-28-2008, 09:16 AM
