585,925 active members*
3,432 visitors online*
    Apr 2013
    1899
    How I move around my heavy DIY CNC
    My machine is nowhere near as nice or heavy as many others here, but I don't feel I have to be ashamed of it, I built it completely on my own, cut and drilled, threaded every bit of it, so all in all, I am pretty proud of it.
    So, this is how my CNC looked like a few weeks ago.
    Attachment 458954
    I built this a few years ago and use it mainly for plastics and PCB, but also mill aluminium pretty well on it, so for my needs the machine is definitely good enough. From the start I kept track of the weight, but as time went by, the machine got heavier and heavier after all the modifications I constantly make. I knew it was more than 100kg, but not more exactly. The other day I managed to check it more precisely by placing two ordinary bathroom scales under it, just for fun, to check the exact weight. One showed 60kg, the other showed 65kg, so now I know that the total weight was 125kg, which explains why it was more and more difficult to move it around. I noticed this "problem" some months ago when I moved to another, larger room in my house. This is the way I had to do it:
    Attachment 458956
    I had to lower the round black feet on all four corners to lift the machine, remove the wooden blocks the machine normally resting on, raising the black plastic feet to lower the machine on the four castors, move it to the new place, lift it again, place the wooden blocks under it and lower the machine on those. It was a complicated operation, which actually put me off from doing any improvements and modifications, so I decided to do something about it.
    What I did was, I ordered four linear actuators, installed castors on them and installed on the four feet.
    https://youtu.be/4sUEEOjzpeg
    After installing the actuators, my CNC looks like this.
    Attachment 458958
    Each linear actuator can lift 152kg, so I knew I had good margin. The only thing I am not that happy about is that they extend to three different lengths, only two are the same, but in this application that is not critical.
    I made a control box with some relays, a switch and three LEDs to control the actuators.
    Attachment 458960
    https://youtu.be/aB5bX-nn4K4
    Of course, simplest would have been to use a 3-way two pole switch, but I had no such thing in my boxes and drawers. I had however more than enough relays to make it, so I went for a relay based solution.
    The box isn't as nice as I wished for, but it does what I wanted it to do. This was the first time I made this sort of engraving, so it's OK for now, but I will make a new box top with better polished surface another time. Now it is easy to move my machine around, just flipping a switch and that lifts the machine with the wooden blocks permanently attached under it's feet. No more crawling on floor for a simple move.
    Anyway, the subject of moving around heavy machines is often discussed, also if CNC can be permanently on castors or should rest with better stability. Initially, my CNC was on large, heavy duty castors placed under it´s four feet (not like you see in the top picture), but even though each had a lock, preventing rolling, the CNC was shaking because of the rubber wheels and the fact that they are wheels. So my conclusion was that castors are good for moving the machine, but using it resting on castors is not a good idea at all. I considered fixing it the wall, but then I concluded that it will shake the walls and it would be better to let it rest on wooden blocks on my floor. Under the teak parquet I have concrete floor, so there is no floor vibration, and the CNC is resting firmly on the soft-ish wooden blocks, which are soft enough to dampen the machine vibration, but hard enough to provide very good stability. Actually, my CNC works much better, with higher speed, acceleration and accuracy than it had when it was resting on castors.
    I feel that my solution with the linear actuators can be used on many other machines as well, and is not adding much to the price of those 400kg + machines, so I don't understand why we don't see any of those. I have seen people building hydraulic systems, which may be needed to machines which are REALLY heavy, but for the few hundreds of kg our machines weight, I think a pure electric linear actuator is more than enough, simple to implement and can lift quite a lot. Even if a machine weights more than 600kg, it is possible to use the type of cheap actuators I am using, but of course, it may need more than four. In general, I think it is a good idea to leave some margin, personally I'd feel comfortable to use it up to 400kg, which would leave a 200kg in that case.
    In short, I don't think it is a good idea to build CNC which rests only on castors, it is much better to lower the castors when the machine needs to be moved.
    Apr 2013
    1899
    Re: How I move around my heavy DIY CNC
    This project is finished. Yesterday I swapped out the PSU to a more powerful one and released the last part of my video series about it.
    https://youtu.be/p-EtlIY0Zb8
    The new PSU was necessary because the needed current was too high for the 7A PSU I initially chose to use. I was not sure about how much current is needed, and was a bit naive, thought that since my CNC is far below of the maximum load, I would need far less than the maximum current, but that seems to be the case only for "normal" operation, which is starting from zero load, i.e. when the linear actuators are fully up and the castors are dangling. From there I could drive the actuators to full extension, but if I stopped before, I could not restart. When the CNC was resting on the castors I could not restart to push the CNC further up, because the load to start from that position was just too much for the 7A PSU so the PSU just stalled, no movement. In that situation I had to lower the machine completely and restart from there. This I though was not very safe. Imagine if my toe gets caught under one of the CNC feet and there is no way to change direction, meaning I have to lower the CNC fully on my toe before lifting it up again... not good for my future...
    Attachment 459358
    ...so I changed to an 82A 12V PSU I have, and with that it can be stopped, restarted or instantly swap direction any time I want to.
    Anyway, I am now ready, it works well and no regrets, would do it again if I had to. Yes, it is over-engineered, but it was fun and I really like this solution to a fairly simple problem. It's really cool in my opinion and hope it inspired a few people, so thumbs up for me.
  1. Replies: 0
    Last Post: 03-12-2016, 08:30 AM
  2. Replies: 2
    Last Post: 11-11-2015, 01:55 PM
  3. move to saved location or move a fixed distance
    By BikeCourse in forum Mach Mill
    Last Post: 03-21-2015, 03:06 AM
  4. plunge after first move and retract after last move
    By Joesph Jackman in forum Mastercam
    Last Post: 02-24-2012, 06:15 AM
  5. Replies: 6
    Last Post: 03-14-2011, 09:41 PM
